Daikin Integration problem
heard, that we have a working integration for newer Daikin models.
I tried it, I know my IP-Address but were to get the ‘API’-Key?
I have an SSID and a Key for that WLAN, but thats not the right stuff, I guess.
Thanks for helping.
With best regards
Gerhard
Hello Gerhard Kreuzer,
I think your answer is here…
On that page in particular:
Thanks a lot, but …
I used the ‘Onecta’ app to integrate one box to my own WiFi, and this works.
The box gets an IP from my DHCP.
==> I know the IP for sure.
In the app, I see ‘Adapter: BRP069C4x’ ==> I have to left the fields Api-Key and Pwd blank.
After doing so, I get an ‘Unexpected Error’ message.
What do I wrong?
When I ping the IP of the box, I get positiv response, so the network stuff is not an issue, isn’t it?
Any ideas to try something out?
Edited:
In LogViewer I found now:
2025-03-10 10:48:54.108 ERROR (MainThread) [homeassistant.components.daikin.config_flow] Empty values.
==> Correct, I was forced to do so …
With best regards
Gerhard
You can only use the third party cloud integration for that model.
You need to sign up for an API key. See:
Ok, to say it short:
Cloud, or another WiFi adapter needed …
==> Cloud is a no go, I have to look for another adapter for my 10 boxes.
Any suggestions? Faikin?
With best regards
Gerhard
Faikin is very good.
Thanks, will check that.
