Hi people, I’m using the Daikin Madoka integration from mduran80 on GitHub for connecting my HA to our Daikin AC with BRC1HHDW remote bluetooth control. With an USB dongle from Asus (BT500) I succeeded to set up a connection and integrate the AC unit in HA. After a few days the integration on my dashboard says that the device is unavailable. Restoring a backup from a day early solves the problem. In the mean time I have had the issue for another 4 times. When I look in my log I see the following errors:
Logger: pymadoka.connection
Source: runner.py:120
First occurred: 7 februari 2023 om 16:26:48 (2369 occurrences)
Last logged: 10:22:09
[org.bluez.Error.Failed] le-connection-abort-by-local
[org.bluez.Error.Failed] Operation already in progress
[org.bluez.Error.Failed] br-connection-canceled
Characteristic 2141E111-213A-11E6-B67B-9E71128CAE77 not found!
No backend with an available connection slot that can reach address B8:F2:55:19:07:AB was found
Further in the logs I find another error message:
Logger: homeassistant.components.bluetooth.scanner
Source: components/bluetooth/scanner.py:301
Integration: Bluetooth (documentation, issues)
First occurred: 7 februari 2023 om 23:28:55 (1 occurrences)
Last logged: 7 februari 2023 om 23:28:55
hci0 (04:42:1A:55:C4:D0): Failed to restart Bluetooth scanner: hci0 (04:42:1A:55:C4:D0): Failed to start Bluetooth: [org.bluez.Error.InProgress] Operation already in progress
File “/usr/src/homeassistant/homeassistant/components/bluetooth/scanner.py”, line 219, in _async_start
await self.scanner.start() # type: ignore[no-untyped-call]
File “/usr/local/lib/python3.10/site-packages/bleak/init.py”, line 156, in start
await self._backend.start()
File “/usr/local/lib/python3.10/site-packages/bleak/backends/bluezdbus/scanner.py”, line 191, in start
self._stop = await manager.active_scan(
File “/usr/local/lib/python3.10/site-packages/bleak/backends/bluezdbus/manager.py”, line 368, in active_scan
assert_reply(reply)
File “/usr/local/lib/python3.10/site-packages/bleak/backends/bluezdbus/utils.py”, line 20, in assert_reply
raise BleakDBusError(reply.error_name, reply.body)
bleak.exc.BleakDBusError: [org.bluez.Error.InProgress] Operation already in progress
File “/usr/src/homeassistant/homeassistant/components/bluetooth/scanner.py”, line 346, in _async_restart_scanner
await self._async_start()
File “/usr/src/homeassistant/homeassistant/components/bluetooth/scanner.py”, line 301, in _async_start
raise ScannerStartError(
homeassistant.components.bluetooth.scanner.ScannerStartError: hci0 (04:42:1A:55:C4:D0): Failed to start Bluetooth: [org.bluez.Error.InProgress] Operation already in progress
And finally another error message:
Logger: homeassistant.helpers.integration_platform
Source: loader.py:761
First occurred: 7 februari 2023 om 15:28:33 (9 occurrences)
Last logged: 7 februari 2023 om 15:32:07
Unexpected error importing daikin_madoka/media_source.py
Unexpected error importing daikin_madoka/logbook.py
Unexpected error importing daikin_madoka/group.py
Unexpected error importing daikin_madoka/energy.py
Unexpected error importing daikin_madoka/hardware.py
File “/usr/src/homeassistant/homeassistant/helpers/integration_platform.py”, line 40, in _async_process_single_integration_platform_component
platform = integration.get_platform(platform_name)
File “/usr/src/homeassistant/homeassistant/loader.py”, line 744, in get_platform
cache[full_name] = self._import_platform(platform_name)
File “/usr/src/homeassistant/homeassistant/loader.py”, line 761, in _import_platform
return importlib.import_module(f"{self.pkg_path}.{platform_name}")
File “/usr/local/lib/python3.10/importlib/init.py”, line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File “”, line 1050, in _gcd_import
File “”, line 1027, in _find_and_load
File “”, line 1004, in _find_and_load_unlocked
ModuleNotFoundError: No module named ‘custom_components.daikin_madoka-main.cast’
I cannot find a working solution for this problem. Is anyone familiar with this?
My setup:
Dell laptop with HA in a VM on Virtualbox
Home Assistant 2023.1.7
Supervisor 2023.01.1
Operating System 9.5
Frontend-version: 20230110.0 - latest
