Daikin remote / broadlink rm4 hub/transmitter
Hello
I have a daikin mini-split and purchased a broadlink rm4 pro. The remote to the daikin has a single power button but when learning the IR codes using the learn command service with the broadlink intergration I get 2 different codes
    "version": 1,
    "key": "broadlink_remote_a043b018aeb6_codes",
    "data": {
        "daikin": {
            "power_on": "JgAWAQABQQABQAABRAABQJlQDggQHQ4dDQoOHg4IDwoOCw4KDh4NCg4KDh4NCQ8KDh4NCg4KDgoOHg0KDgoOCg8JDwoOCg4KDwgPCg4eDQoOCg4LDgoOHQ0LDh0OCQ8KDgoOHg0eDQkPCg4eDQoOCg4KDgoPCBAdDQoPCQ4eDQoOCw4dDQoOHg0eDQoOCg4KDx0OAAKYDh0OCA8KDgoOCg4eDggPHg0KDgoOCg8JDwoOCg4KDgoOCg4KDgsOCg4KDgoOCg4KDgoOCg4KDwoOCg4KDgoOCg4KDgoOCw4KDgoOCg4KDgoOCg4KDwoOCg4KDgoOCg4KDwgPCg8KDgoOCg4KDgoOCg8dDR4OCBAdDQoOCg4KDgqaAA0F",
            "power_off": "JgAWAQABQQABQQABQgABQZhSDAsMIAsgCw0LHwwNCw0MDAwMDB8LDQwMDB8MDAwMDB8MHwwMDAwMHwwMDAwMHwwMDAwMHwwMDAwNCwwgCw0LDQwMDAwLIAsNDB8LDQwMDAwMHwwfDAwNCwwfDAwMDA0LDB8MDAwfDAwMDQsfDA0LDQsgCw0LIAsfDA0LDQsNCw0MAAKaDB4MDQsNCw0MDAwfCw0LIAsNDAwNCwwMDAwMDAwNCw0MDAwMDAwMDAwMDAwMDQsNDAwMDAwNCwwMDAwNCw0LDQwMDAwMDAwMDA0LDQsNCw0MDAwMDAwMDAwNCw0LDQwMDAwMDAwMDA0LDQsNDAwMDAwfDB8LDQwfCw0LDQwMDAyXAA0F",
            "daikin_power_on": "JgAWAQABQQABQQABQwABQJlRDQkPHg0eDAsOHgwLDgoOCg4KDh4NCg4KDh4NCg4KDh4NHg0KDgoOHg0eDQoOCg4KDh4NCg4eDQoOHg0KDgoOCw4KDgoOHg0KDh4NCg4KDgoOHg0eDQoOCg4eDQoOCg4KDh4NCg4eDQoOCg4eDQoOCw0eDQoOHg0eDR4NHg0eDR4NAAKYDh0NCg4KDgoOCg4eDQoOHwwKDwoOCg4KDgoOCg4KDgoOCg8KDgoOCg4KDgoOCg4LDgoOCg4KDgoOCg4KDgoOCw4KDgoOCg4KDgoOCg4KDgsOCg4KDgoOCg4KDgoOCg4LDgoOCg4KDgoOCg4KDgoOCw4eDB4NCg4eDQoOCg8KDgqZAA0F",
            "daikin_power_off": "JgAUAQABQQABQAABRAABQJlQJR4NHg0KDh4NCg4KDgoOCg8eDAoPCQ8eDQkPCg4eDR4NCQ8KDh4NHg0JDwkPCg4eDQoOHg0KDh4NCg4KDgoOCg4KDh4NCg4eDQoOCg4KDh4NHg4IDwoOHg0KDgoOCw4eDQkPHgwKDwoOHg0JDwoOHg0KDh4NHgweDR4NHg0eDQACmQ4cDggPCg4KDwkPHgwKDx4NCQ8KDgoOCg4KDgoOCg4LDgoOCg4KDgoOCg4KDgoOCw4KDgoOCg4KDgoOCg4KDgsOCg4KDgoOCg4KDgoOCg4LDgoOCg4KDgoOCg4KDgoOCw4KDgoOCg4KDgoOCg4KDgsOHgweDQoOHg0KDgoOCg8KmQANBQAA",
            "daikin_cool_mode": "JgAWAQABQQABQAABRAABQJlQDQsNHg0eDQoOHg0KDgoOCw0LDh4MCw4KDh4NCg4KDh4NCg4eDQoOCg4KDh4NCg4KDh4NCg4eDQoOHg0KDgoOCw0LDgoOHgwLDh4MCw4KDgoOHg0eDQoOCg4eDQoOCg4KDh4NCg4eDQoOCg4eDQoOCw0eDQoOHg0KDh4NCg4KDgsNAAKZDh0NCg4KDgoOCg4eDQoOHg0KDgsNCw4KDgoOCg4KDgoOCg4LDgoOCg4KDgoOCg4LDQoOCw4KDgoOCg4KDgoOCw0LDQsOCg4KDgoOCg4KDgsNCw0LDgoOCg4KDgoOCg4LDQsNCw4KDgoOCg4KDgoOCw0eDR4NCg4eDQoOCg4LDQuZAA0F",
            "daikin_dry_mode": "JgAWAQABRAABPwABQgABQJlRDQkPHgwfDAsNHwwLDQsNCw4eDQoOCg4KDh4NCg4LDQsNHwweDR4NCg4LDR4NCg4LDR4NCw0eDQsNHg0LDQsNCw0LDgoOHgwLDh4MCw4KDgsNHg0eDQoOCg4eDQoOCw0LDR4NCw0eDQsNCw0eDQsNCw0fDAsNHwwLDR8MCw0fDB4NAAKZDh0NCQ8KDgsNCw0eDQsNHg0LDQsNCw0LDgoOCg4KDgsNCw0LDQsNCw4KDgoOCg4LDQsNCw0LDQsOCg4KDgsNCw0LDQsNCw4KDgoOCg4LDQsNCw0LDQsOCg4KDgoOCw0LDQsNCw0LDgoOCg4KDgsNCw0eDR4OCQ4eDgkOCw0LDQuaAA0F",
            "daikin_fan_mode": "JgAWAQABQQABQQABQwABQJlRDQoOHg0eDAsNHwwLDQsOCg4KDgoOHg0KDgoOCw0LDR8MCw0LDQsOHgwLDh4MCw0LDh4NCg4eDQoOHgwLDgoOCw0LDQsNHg0LDR4NCw0LDQsNHwweDQsNCw0fDAsNCw0LDh4MCw4eDAsOCg4eDAsOCg4eDQoOHg0KDgoOCw0LDR4NAAKZDR4MCw4KDgoOCg4eDQoOHg0LDQsNCw0LDQsNCw4KDgoOCw0LDQsNCw0LDQsOCg4LDQoOCw0LDQsNCw4KDgoOCw0LDQsNCw0LDgoOCg4KDgsNCw0LDQsNCw4KDgoOCg4LDQsNCw0LDgoOCg4KDgoOCw0eDR4NCg4eDQoOCg4LDQuZAA0F",
            "daikin_heat_mode": "JgAWAQABQQABQAABRAABQJlPDwgPHg0eDQoOHg0KDgoOCg4KDwoOCg4eDR0NCw0LDh4NCg4KDgoOHg0KDh4NCg4KDh4NCg4eDQoOHg0KDgoOCg4KDgoOHg0KDh4NCg4KDgsOHg0dDQoOCw4dDQsOCg8IDx4NCg4eDQoOCg4eDQoOCg4eDQoOHg0KDh4NCg4eDR4NAAKYDh0NCg4KDgoOCw4eDAoPHgwLDgoOCg4KDgoOCg4KDgsNCw4KDgoOCg4KDgoOCg4LDQsOCg4KDgoOCg4KDgoOCw4KDgoOCg4KDgoOCg4KDgsOCg4KDgoOCg4KDgoOCg4LDgoOCg4KDgoOCg4KDgoOCw4dDR4NCg4eDQoOCg4LDgqZAA0F",
            "daikin_auto_mode": "JgAWAQABQgABQAABRAABQJlQDgkOHg0eDQoOHg0KDgsNCw0LDR8MCw0fDB4OCQ4LDQsNHwwLDQsOHgwLDR8MCw4KDh4NCg4eDQoOHgwLDgoOCw0LDQsNHg0LDR4NCg4LDQsNHwweDgkOCw0fDAsNCw0LDh4NCg4eDQoOCg4eDQoOCw0eDQoOHg0KDgsNCw0LDR4NAAKZDh0NCQ8KDgoOCw0eDQsNHg0LDQsNCw0LDQsOCg4KDgsNCw0LDQsNCw4KDgoOCg4LDQsNCw0LDQsOCg4KDgoOCw0LDQsNCw4KDgoOCg4LDQsNCw0LDQsOCg4KDgoOCw0LDQsNCw4KDgoOCg4KDgsNCw0fDB4NCw0eDQsNCw0LDQuaAA0F"
home assistant and broadlink aside, if i press the button the unit always toggles on or off with each button press even when purposely trying to get the unit and remote out of sync.
In home assistant either of the power on or power off IR codes will toggle the daikin regardless of it’s state.
can someone explain what may be happening here?
** edit further reading it appears my remote considers all the settings of the remote. on/off, mode, temp, fan info, etc and sends it across. This may explain the different codes.
Is there a proper process for deleting these codes out of HA?
