There was maintenance every day and every 3 days starting at 2:00 a.m. I uncheck all cases and it did kill the cpu usage. Temperature is back to normal now.
Good you found it. However now that you know what it is why not let it do its work?
For me Glances used a noticeable amount of ressources and it increased the CPU temp by a few degrees. Therefore I’ve uninstalled it again but your mileage may vary.
I can confirm this, I don’t uninstall it but I don’t leave it running. I only start it if there is something I want to look into, then stop it right after.
I didn’t realize there was an addon for Glances. I installed it directly on Debian through the MacOS Terminal. I will look into it if it keeps running while I’m not looking actively in a Terminal window.
