I have been getting almost daily crashes on a new installation using a Mini PC 11th Gen Intel N5095 with 8GB RAM (https://smile.amazon.com/dp/B09ZLDBC8X). The Home Assistant VM has to be Forced Reset in order to recover
I’m running Home Assistant OS 9.5 (core 2023.2.3) in KVM on Linux Mint 21.1 (5.15.0-58-generic)
I have tried multiple full host OS rebuild along with multiple full rebuilds of Home Assistant OS. This has been a consistent issue for the full month I’ve been trying to use HA
I’m in the process of converting my zwave and Insteon devices from my ISY994i to HA. While I’m really liking HA, the stability has me very concerned
I was able to pull the logs from HAOS. Here is a snippet of what I believe is the problem area.
Feb 08 18:46:10 homeassistant kernel: invalid opcode: 0000 [#1] SMP NOPTI
Feb 08 18:46:10 homeassistant kernel: CPU: 0 PID: 1953 Comm: coredns Not tainted 5.15.90 #1
Feb 08 18:46:10 homeassistant kernel: Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 0.0.0 02/06/2015
Feb 08 18:46:10 homeassistant kernel: RIP: 0010:asm_exc_invalid_op+0x0/0x20
Feb 08 18:46:10 homeassistant kernel: Code: 08 00 00 48 89 c4 48 89 e7 48 8b 74 24 78 48 c7 44 24 78 ff ff ff ff e8 ae d9 f8 ff e9 f9 09 00 00 66 0f >
Feb 08 18:46:10 homeassistant kernel: RSP: 0018:ffffb010818b3028 EFLAGS: 00010046
Feb 08 18:46:10 homeassistant kernel: RAX: 0000000000000000 RBX: ffffb010818b3d00 RCX: 00000000bdee2e3b
Feb 08 18:46:10 homeassistant kernel: RDX: 0000000000000000 RSI: 00000000281ff3a1 RDI: ffff965580839304
Feb 08 18:46:10 homeassistant kernel: RBP: ffffb010818b3cb0 R08: ffffb010818b3cb0 R09: 0000000000000000
Feb 08 18:46:10 homeassistant kernel: R10: ffffb010818b3ed8 R11: 0000000000000000 R12: 000000c000380148
Feb 08 18:46:10 homeassistant kernel: R13: 0000000000000000 R14: ffffb010818b3d38 R15: ffff96559ed22ac0
Feb 08 18:46:10 homeassistant kernel: FS: 000000c000380090(0000) GS:ffff9655bbc00000(0000) knlGS:0000000000000000
Feb 08 18:46:10 homeassistant kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Feb 08 18:46:10 homeassistant kernel: CR2: 000000c0000c7010 CR3: 000000011ef88000 CR4: 0000000000350ef0
Feb 08 18:46:10 homeassistant kernel: Call Trace:
Feb 08 18:46:10 homeassistant kernel: <TASK>
Any assistance would be greatly appreciated
