Hi, I’m pretty new with HA. I run currently HA on a raspberry PI (fullpageos version) in a kiosk mode. The current weather in the “weather forecast card” gets updated from time to time but not the forecast on daily or hourly basis. Does someone has a hint how to fix that?
You didn’t mention what version of HA you’re on or your weather integration. With 2024.4.x the older method of getting forecasts was removed, so if you’re on that version, both your card and weather integration may need to be updated to work with the new method.
You mentioned I have to do an update. Is the weater-forecast not a part of Core and automatically updated? The weather integration is currently 1.0.3 which is the newest.
The weather functions are core, but each Weather addon has to be updated to use the new functions. It looks like the weather addon you are using is installed through HACS, so it is not part of core and likely needs to be updated. You’ll need to contact the developer for that weather addon and ask for them to update it.
