Daily Utility Meter occasionally does not reset itself / reinstates the value from previous day
Occasionally the daily utility meter I’ve created does not properly resets itself and restores previous day value after 10minutes (see the graph below). Any ideas why and how to fix it? I can correct the data manually by modifying the core.restore_state file, but only when I notice it, if I miss it after the day passes I have a bad value in the history I cannot do anything about.
What’s the source sensor doing?
Acting normal so it seems to be a problem with utility meter implementation in HA.
I seem to be having a similar issue, but my source sensor is resetting to 0 only to revert back a couple minutes later. It does drop back down 15-20 minutes later, but this is causing my tariff entity (cumulative) to stay at the higher reading and add on from there. I saw some issues with Emporia and HA 2025, but haven’t seen this issue on that list yet.
