This is a customisable daily weather notification sent to your phone that can also include tomorrow’s forecast. The notification icon will update depending on today’s forecast (android only).
The Automation
Trigger
The trigger is set to everyday at a time you specify. This will trigger the automation and send the notification at that time.
Today’s Forecast
Today’s forecast can include the following items:
Condition - weather condition (e.g. Sunny)
Temperature - high and low temperatures.
Precipitation - predicted amount of precipitation.
Wind - the wind speed and wind bearing.
Tomorrow’s Forecast
Tomorrow’s forecast can optionally be appended to the bottom of the notification.
Home Assistant companion application installed on a device.
Notes:
I have based this blueprint on the most popular weather integration (Met.no) and the attributes available. These attributes should be common to other weather integrations as well.
Updates
3/5/24 - Enabled multiple devices to be notified at once.
Notification sounds are controlled through your device or the companion app and not configured by the blueprint.
I don’t want to make it too granular for people so just want one option for wind but you can import the blueprint then edit it to remove the wind bearing part.
Hi, it looks like the free version of that integration only supports ‘hourly’ forecasts every three hours. This only provides the forecasted weather at that point in time.
I can look at adding this in however it’s a bit more complicated. Either I could set a notification to provide the forecast at a specific point in time (e.g. midday) or somehow aggregate the data from the hourly forecast to create my own daily one. I’ll have a think about it.
