So I got 6 sensors reading the temperature on the roof (solar heating pool) the readings go from reading a “valid” reading to invalid = 85.0 Celsius / NAN / NA
there is also an alternative component for dallas; lots of reports on this thread that are worth reading. Bit of fiddling needed. capacitance is a problem. all mine are working … just
@FloatingBoater, if they get to degraded I will change them, i only need 2 or 3 to be operational …
they basicly served their purpose as in:
I did some experiments with solar heating swimming pool water on a shed roof, after the tests where done I kept them to monitor.
if temp reaches above 40-50 C (summer time) i start pumping poolwater through the solar heating, it drops to just above the pool temp (heating 1 or 2 degrees in the proces) if it is equal → turn of pump
@JulianDH sorry i am not getting the alternative / capacitance part could you supply me with a link to the thread(s) please ?
