I’m trying to add a am2320 to existing project that has a dallas temperature currently working. If I add either into configuration without the other they work but when combining the dallas reports Found no sensors.
Hoping someone has idea where I’ve gone wrong?
This is the configuration I’m attempting to get going
i2c:
sda: 4
scl: 5
scan: True
dallas:
- pin: 14
- platform: dallas
address: 0x9F000005CDA7F028
name: "Outside Temperature"
- platform: am2320
temperature:
name: "Greenhouse Temperature"
humidity:
name: "Greenhouse Humidity"
update_interval: 60s
This is the error I get
[17:50:42][C][i2c.arduino:038]: I2C Bus:
[17:50:42][C][i2c.arduino:039]: SDA Pin: GPIO4
[17:50:42][C][i2c.arduino:040]: SCL Pin: GPIO5
[17:50:42][C][i2c.arduino:041]: Frequency: 50000 Hz
[17:50:42][C][i2c.arduino:044]: Recovery: bus successfully recovered
[17:50:42][I][i2c.arduino:054]: Results from i2c bus scan:
[17:50:42][I][i2c.arduino:056]: Found no i2c devices!
[17:50:42][C][dallas.sensor:075]: DallasComponent:
[17:50:42][C][dallas.sensor:076]: Pin: GPIO14
[17:50:42][C][dallas.sensor:077]: Update Interval: 60.0s
[17:50:42][W][dallas.sensor:080]: Found no sensors!
[17:50:42][C][dallas.sensor:089]: Device 'Outside Temperature'
[17:50:42][C][dallas.sensor:089]: Device Class: 'temperature'
[17:50:42][C][dallas.sensor:089]: State Class: 'measurement'
[17:50:42][C][dallas.sensor:089]: Unit of Measurement: '°C'
[17:50:42][C][dallas.sensor:089]: Accuracy Decimals: 1
[17:50:42][C][dallas.sensor:097]: Address: 0x9f000005cda7f028
[17:50:42][C][dallas.sensor:098]: Resolution: 12
[17:50:42][D][am2320:065]: AM2320:
[17:50:42][C][am2320:066]: Address: 0x5C
[17:50:42][C][am2320:070]: Temperature 'Green House Temperature'
[17:50:42][C][am2320:070]: Device Class: 'temperature'
[17:50:42][C][am2320:070]: State Class: 'measurement'
[17:50:42][C][am2320:070]: Unit of Measurement: '°C'
[17:50:42][C][am2320:070]: Accuracy Decimals: 1
[17:50:42][C][am2320:071]: Humidity 'Green House Humidity'
[17:50:42][C][am2320:071]: Device Class: 'humidity'
[17:50:42][C][am2320:071]: State Class: 'measurement'
[17:50:42][C][am2320:071]: Unit of Measurement: '%'
[17:50:42][C][am2320:071]: Accuracy Decimals: 1
[17:50:52][D][api.connection:827]: Home Assistant 2022.12.1 (192.168.1.239): Connected successfully
[17:51:08][D][am2320:047]: Got temperature=22.7°C humidity=71.2%
[17:51:08][D][sensor:124]: 'Green House Temperature': Sending state 22.70000 °C with 1 decimals of accuracy
[17:51:08][D][sensor:124]: 'Green House Humidity': Sending state 71.20000 % with 1 decimals of accuracy
[17:51:09][E][dallas.sensor:112]: Requesting conversion failed
[17:51:09][D][sensor:124]: 'Outside Temperature': Sending state nan °C with 1 decimals of accuracy
