I am in need of bidirectional data flow between my esp01 and the arduino port expander. I am able to control switches and lights, but analog data from the analog ports are proving to be more difficult. I am able to get motion detectors to work, but what I really need are dallas one-wire sensors, and have had good luck in the past using the dallasng library (github://nrandell/dallasng). Here is my code:
binary_sensor:
- platform: custom
lambda: |-
return {ape_binary_sensor(expander1, 7),
ape_binary_sensor(expander1, 8),
ape_binary_sensor(expander1, 9),
ape_binary_sensor(expander1, 10),
ape_binary_sensor(expander1, 14) // 14 = A0
binary_sensors:
- id: switch_1
icon: "mdi:button-pointer"
internal: false
on_press:
- light.turn_on: output_1
- id: switch_2
internal: false
on_press:
- light.turn_on: output_2
- id: pir_sensor0
device_class: motion
- id: pir_sensor1
- id: pir_sensor2
dallasng:
- pin: 14
update_interval: 4s
#address: "0x0d3ce1e380717c28"
#name: "Temperature"
#resolution: 12
#expire_after: 300s
#filters:
# - filter_out: NAN
# - round: 2
It compiles until it hits the address: 0x0d3ce1e380717c28, then the compiler complains that the syntax is incorrect and the yaml is badly formatted. I am sure this is a simple error, but solution eludes me.
