Im not sure if any others have any Danalock experience, but i only get one entity with my Danalock which is:
entity_id: lock.husdor_locked_21_0
This always shows as state “unlocked”, and if i trigger the switch it tries to lock again. When it then gets locked i cannot unlock it either, so basically the only thing i can get done with my Danalock trough zwave is to lock it.
Any others which want to share their experience with Danalock?
Note: The lock is zwave secure included.
Whats the practical difference between advanced (1) and mode 2 as you mention?
“0 = Simple supported by all controllers that support
door locks. 1 = Advanced, more specific reports
through notification Command Class. 2 = No Door
lock operation reports are sent unsolicited. Should
not be used. Use Notification CC enable instead.”
I tested using advanced (which is 1) and now i get more status, but it shows as unlocked when its locked and vice versa.
