@echo Is it to late to send it back and replace with zigbee version?
It used to Work when I used the old Open Zwave-version. However I have not been able to make it work with Zwave JS.
Yes, had it for almost one year now. But I bought an other lock.
Yale Linus. Works flawlessly with Agust integration. Even has magnet sensor to see if door is opened or closed.
I have Danalock V3 BT + Danabridge V3.
Is there a chance that this will work with HA?
Hi There,
my Danalock V3 BT + ZW did not work with Zwave-JS and Z-Stick 5. But it works fine with Zwave-JS and Z-Stick 7.
Great news Zigbee was fixed with new Update version 0.22.4, DanaLock v3 (zigbee) works for more than 24 hours and didn’t loose connection since then. I could not use the lock after updating from firmware 0.17.4
Hi, can you provide quick guide how you managed to set it up?
Do you recommend to buy the BT+Zigbee version today?
Well since my last message it still works on latest Danalock v3 update. So if you have good price on it I think it is good addition to Home Assistant, I use it with Alarmo (HACS Integration) along with Aeotec Sirens, Xiaomi/Aqara/Fibaro door/window sensors and motion detectors as home alarm
