Danalock V3 official support for HA
Hello
I am looking to buy Danalock V3 and it looks like (from checking other threads) that it is already possible to add it to HA. But no official component… yet.
I sent an email to their support and HA support is testing & planned for beginning of next year!
I am considering buying a Danalock V3 - but did it ever get officially supported and what is the general opinion of it. Does it work reliable and worth the cost?
Hi @Morten_DK
I have a z-wave stick in the RPi4 and apart from the quirks in the aeotec stick, it works very reliably.
With the later versions of Ha, the Z-wave configuration has gotten way simpler, and it’s quite a bit easier to add the lock than before.
One thing though, I have the BTZE version of DL3, and to add it to Ha, you should use the app and activate the Z-wave from that. There is a rather simple guide, a 5 step one, and it’s even simpler now:
If you want help with it, let me know, and we’ll do it in our native tounge :smiley:
Tak :slight_smile:
Sounds great that it is working as expected - I’ll come back to you in case I run into some issues :slight_smile:
Hey Fribse
Has just gotten a new door and wants to buy the Danalock for my Home Assistant system.
I am not 100% sure what version of Danalock to buy, probs. gonna buy it from Proshop here i DK…
I am planning to buy the Bridge, keypad and a lock. But I don’t know which version to buy?
I got a Aeotec z-stick USB (z-wave) connected to my Rasberry w. HA.
I wouldn’t buy the bridge, just my 2 cents, I had the bridge running on a phone for a long while, and it was very unstable, so I switched to HA as they were simply too slow to release the standalone bridge (waited for more than a year), and now operate it through that, works every time.
The hardware bridge is of course a LOT more stable, but I don’t see the need for it, when I have the z-wave integration to HA
As you already have z-wave, I would go for the bluetooth+z-wave. If I could choose today, I would probably select zigbee instead, as the rest of the house is on zigbee :slight_smile:
Then set the lock up via the phone as normal (via bluetooth), and then enroll it into z-wave via the app afterwards (like the steps above).
Then you can make a card for the lock that mimics the app.
I did it like this:
cards:
  - color_type: blank-card
    type: 'custom:button-card'
  - entity: lock.poly_control_danalock_v3_btze_locked
    show_entity_picture: true
    state:
      - entity_picture: /local/images/lock-locked.png
        tap_action:
          action: call-service
          service: lock.unlock
          service_data:
            entity_id: lock.poly_control_danalock_v3_btze_locked
        value: locked
      - entity_picture: /local/images/lock-unlocked.png
        tap_action:
          service: lock.lock
          service_data:
        value: unlocked
    style: |
      ha-card{background:transparent;box-shadow: none;}
type: horizontal-stack
That makes a horizontal stack, with an empty slot, the lock, and then another empty slot again and using the custom button card as found in HACS.
I placed the images in /config/www/images/
lock-locked lock-unlocked
WOW! Thanks for that fantastic answer.
I really did/do not know what the bridge was/is used for, I just guessed it was for connecting it to z-wave…
  1. Only thing is I am a bit worried the z-wave would not be able to connect because of distance between the lock? and the RP w. HA/USB dongle, or is there some adapter to help with the distance?
  2. Currently I only use the z-wave for an alarm Sirene… And the only Zigbee I have is the Philips HUE hub… So for me it must be Z-wave version, unless the Zigbee could solve the “maybe” distance challenge I might have.
Best regards Jan, Tårnby, Amager
The distance could be an issue, I have mine 1 m from the door :slight_smile:
There could be a small advantage for z-wave in regards to the range, as that is on 900 MHz, where zigbee is 2.4 GHz.
In case there is a problem, you need a repeater ‘underway’. In the zigbee world it’s just a device running on an outlet of some sort, in z-wave it’s a repeater (not sure if the individual outlet driven devices also do it). But wait until you see if there really is a problem before buying it.
Oh, and I’m from Greve, work in CPH, so I’m right around the corner :smiley:
Thanks a lot :metal:
Just ordered keycode thingy and the BT/Z-wave version, so I am ready rock pretty soon.
Think I will move the RP to the center of the house, that should give it a better chance, only about 6 meters and a brick wall then.
And now working perfectly. Again thanks.
Now we also have a keypad outside my house we can use to disarming our inside Alarm setup i HA. And use the unlock Danalock feature inside HA to disarm…
Going to look at this soon together with battery notifications.
I’m wondering if its possible to UNLOCK the danalock without unlocking in total
i mean in german “Aufschließen ohne die Türfalle zu ziehen”
I don’t know how to explain in english ^^
This “new” feature is available in the german danalock app
The trick is to hit in locked mode the lock button again instead of the unlock.
Any idea how to do this in HA?
as well HA support this 3rd state already i see :slight_smile:
is anyone able to realize this via Z-Wave as well?
Hi. Wonder if anyone has experience with the zigbee version of danalock v3. I assume it supported in HA with deconz, but is it reliable. Secondly, is HA-HomeKit integration supported, to allow the zigbee version to be operated via HomeKit As well.
Thx
Michael
see here for ZWave version with OpenZWave addon from supervisor
I just got a danalock zigbee. I can open/close without any issues. The status is unreliable, since I have enabled End-to-end operation. Unfortunately I don’t get the battery info, which would be nice
Via ZHA, the lock now seems to show battery status however this, and lock status is not correct and doesn’t update
I installed my danalock v3 zigbee yesterday and i have tested it out. First connected to HA with ZHA and lock controls worked fine, but couldn’t get lock states correctly. Today I connected it with deConz. With that i can control lock, but it still wont show state correctly. And when I go to deConz setting and select door lock and read attributes it updates correct state to home assistant. Also I use conbee II for lock connections.
Is there any way to make this work right?
Edit: Okay, for some reason it updates states now when controlling lock. But just noticed i don’t see battery sensor. That 1 worked fine with ZHA.
@Keki I have Danalock on ZHA via a Conbee II. To get battery state and lock state I pulled the battery from the lock, put them back in and reset the link to HA from the Danalock app. Worked like a charm.
I found the Danalock app just doesn’t give much control so I have rebuilt control in NodeRed and disabled auto unlock from Danalock and setup notifications via Companion App. The lock now works just how I want it to. If anyone is interested:
[{"id":"48bbd268.e51fe4","type":"tab","label":"Danalock","disabled":false,"info":""},{"id":"1c8ae54c.e53413","type":"group","z":"48bbd268.e51fe4","name":"Door Unlocked, Opened, Closed and Lock","style":{"label":true,"color":"#000000"},"nodes":["8c539b86.df5588","fb65469f.14fd2","a528c20e.71ce8","f8f78f36.e7a708","3c8405b5.75e482","1d6f8c96.83c22b","b5f4b2b.2428e5","71be1352.b56944"],"x":34,"y":1179,"w":1532,"h":142},{"id":"22ce619e.5c8996","type":"group","z":"48bbd268.e51fe4","name":"Send iOS Push Notification - Failed To Lock","style":{"fill":"#addb7b","label":true,"color":"#000000"},"nodes":["f4583c67.7efc18","b9439249.d0e858","fa592782.15e12"],"x":1594,"y":1219,"w":692,"h":82},{"id":"386c77db.fe12d","type":"group","z":"48bbd268.e51fe4","name":"Cheryl Lock/Unlock","style":{"fill":"#ff7f7f","label":true,"color":"#000000"},"nodes":["4931034d.6c664c","fa4facac.69e8e8","aa05f482.c8df5","f8c8be87.ec239","8f2c497f.f196d8","67b6b09e.cc13c","74184c92.ada92c","3b70cd11.479612","7ee2cb43.4efe9c","75d1d7e8.2e6ec","d58de43b.fc9108"],"x":34,"y":319,"w":1572,"h":242},{"id":"587ec5cd.31bd2c","type":"group","z":"48bbd268.e51fe4","name":"James Lock/Unlock","style":{"fill":"#ff7f7f","label":true,"color":"#000000"},"nodes":["7b2a46d5.3c702","300a76e9.48a96a","aae03745.2c5b2","6d9bc30e.301184","c01c67a0.f3aa9","8b0c9caf.68f5f8","59f6d36b.4b14cc","df7a57eb.03483","fbae4b12.f63148","f8574a6a.61f4a8","aa885953.460048","689381bb.34abb","a3379816.d3d738","cfbc6294.6d2ce"],"x":34,"y":19,"w":1632,"h":242},{"id":"eb3e7517.630068","type":"group","z":"48bbd268.e51fe4","name":"Send iOS Push Notification - Lock and Unlock Status","style":{"fill":"#addb7b","label":true,"color":"#000000"},"nodes":["20b990fe.068568","cb163531.d23308","1851c9f8.07e88e","9cc1ace.1ca6cd","18776524.8f4353","d30a09b0.de6a68","284eb9a6.7aa8ee","a2ed941e.da0a3","a10871ff.157138"],"x":54,"y":1559,"w":1192,"h":182},{"id":"f68f9928.e9e058","type":"group","z":"48bbd268.e51fe4","name":"Door Unlocked, Left Unlocked","style":{"label":true,"color":"#000000"},"nodes":["ec849ce9.823278","518de0a4.be93","e0036b68.a65b7","4384adbd.fa9a2c","b8770ca.81a70f","4da9b7b0.e911f8","569d0765.dcc62","812ba674.19d34"],"x":34,"y":1359,"w":1392,"h":162},{"id":"c01c67a0.f3aa9","type":"delay","z":"48bbd268.e51fe4","g":"587ec5cd.31bd2c","name":"","pauseType":"delay","timeout":"30","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":580,"y":120,"wires":[[]]},{"id":"f8574a6a.61f4a8","type":"server-state-changed","z":"48bbd268.e51fe4","g":"587ec5cd.31bd2c","name":"James","server":"9f14629c.16082","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_boolean.james_present","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"x":130,"y":160,"wires":[[]]},{"id":"689381bb.34abb","type":"server-state-changed","z":"48bbd268.e51fe4","g":"587ec5cd.31bd2c","name":"James Wi-Fi Amplifi","server":"9f14629c.16082","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.amplifi_james_iphone_12_pro_max","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"x":150,"y":60,"wires":[[]]},{"id":"a3379816.d3d738","type":"server-state-changed","z":"48bbd268.e51fe4","g":"587ec5cd.31bd2c","name":"James Wifi Companion App","server":"9f14629c.16082","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.james_iphone_12_pro_max_app_ssid","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"x":180,"y":100,"wires":[[]]},{"id":"cfbc6294.6d2ce","type":"switch","z":"48bbd268.e51fe4","g":"587ec5cd.31bd2c","name":"Arriving or Leaving","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"JandC","vt":"str"},{"t":"eq","v":"Not Connected","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":470,"y":60,"wires":[[],[]]},{"id":"4931034d.6c664c","type":"server-state-changed","z":"48bbd268.e51fe4","g":"386c77db.fe12d","name":"Cheryl Home Switch","server":"9f14629c.16082","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_boolean.cheryl_present","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"x":150,"y":480,"wires":[[]]},{"id":"fa4facac.69e8e8","type":"switch","z":"48bbd268.e51fe4","g":"386c77db.fe12d","name":"Arriving or Leaving","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":370,"y":480,"wires":[["8f2c497f.f196d8"],["aa05f482.c8df5"]]},{"id":"aa05f482.c8df5","type":"api-call-service","z":"48bbd268.e51fe4","g":"386c77db.fe12d","name":"Cheryl Leaving Lock the door","server":"9f14629c.16082","version":1,"debugenabled":false,"service_domain":"lock","service":"lock","entityId":"lock.front_door_lock","data":"","dataType":"jsonata","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":630,"y":520,"wires":[[]]},{"id":"f8c8be87.ec239","type":"api-call-service","z":"48bbd268.e51fe4","g":"386c77db.fe12d","name":"Unlock the door","server":"9f14629c.16082","version":1,"debugenabled":false,"service_domain":"lock","service":"unlock","entityId":"lock.front_door_lock","data":"","dataType":"jsonata","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":740,"y":420,"wires":[["74184c92.ada92c"]]},{"id":"8f2c497f.f196d8","type":"delay","z":"48bbd268.e51fe4","g":"386c77db.fe12d","name":"","pauseType":"delay","timeout":"30","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":560,"y":420,"wires":[["f8c8be87.ec239"]]},{"id":"67b6b09e.cc13c","type":"delay","z":"48bbd268.e51fe4","g":"386c77db.fe12d","name":"","pauseType":"delay","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1480,"y":360,"wires":[["3b70cd11.479612"]]},{"id":"74184c92.ada92c","type":"ha-wait-until","z":"48bbd268.e51fe4","g":"386c77db.fe12d","name":"Wait Until Front Door Open","server":"9f14629c.16082","outputs":2,"entityId":"binary_sensor.front_door_open_close_sensor","entityIdFilterType":"exact","property":"state","comparator":"is","value":"on","valueType":"str","timeout":"10","timeoutType":"num","timeoutUnits":"minutes","entityLocation":"","entityLocationType":"none","checkCurrentState":true,"blockInputOverrides":true,"x":980,"y":400,"wires":[["7ee2cb43.4efe9c"],["3b70cd11.479612"]]},{"id":"3b70cd11.479612","type":"api-call-service","z":"48bbd268.e51fe4","g":"386c77db.fe12d","name":"Cheryl Ariving Lock the door","server":"9f14629c.16082","version":1,"debugenabled":false,"service_domain":"lock","service":"lock","entityId":"lock.front_door_lock","data":"","dataType":"jsonata","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1460,"y":480,"wires":[[]]},{"id":"7ee2cb43.4efe9c","type":"ha-wait-until","z":"48bbd268.e51fe4","g":"386c77db.fe12d","name":"Wait Until Front Door Closed","server":"9f14629c.16082","outputs":1,"entityId":"binary_sensor.front_door_open_close_sensor","entityIdFilterType":"exact","property":"payload","comparator":"is","value":"off","valueType":"str","timeout":"0","timeoutType":"num","timeoutUnits":"minutes","entityLocation":"","entityLocationType":"none","checkCurrentState":true,"blockInputOverrides":true,"x":1260,"y":360,"wires":[["67b6b09e.cc13c"]]},{"id":"16e1033e.0c85b5","type":"change","z":"48bbd268.e51fe4","name":"Stop timer","rules":[{"t":"delete","p":"payload","pt":"msg"},{"t":"set","p":"payload","pt":"msg","to":"reset","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":610,"y":280,"wires":[["74184c92.ada92c","59f6d36b.4b14cc"]]},{"id":"892366c0.1b58c","type":"inject","z":"48bbd268.e51fe4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":450,"y":280,"wires":[["16e1033e.0c85b5"]]},{"id":"75d1d7e8.2e6ec","type":"inject","z":"48bbd268.e51fe4","g":"386c77db.fe12d","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":1160,"y":480,"wires":[["3b70cd11.479612"]]},{"id":"8c539b86.df5588","type":"server-state-changed","z":"48bbd268.e51fe4","g":"1c8ae54c.e53413","name":"Danalock Unlocked","server":"9f14629c.16082","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"lock.front_door_lock","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"unlocked","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"x":150,"y":1220,"wires":[["1d6f8c96.83c22b","f8f78f36.e7a708"],[]]},{"id":"fb65469f.14fd2","type":"api-call-service","z":"48bbd268.e51fe4","g":"1c8ae54c.e53413","name":"Lock the door","server":"9f14629c.16082","version":1,"debugenabled":false,"service_domain":"lock","service":"lock","entityId":"lock.front_door_lock","data":"","dataType":"jsonata","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1080,"y":1220,"wires":[["b5f4b2b.2428e5"]]},{"id":"a528c20e.71ce8","type":"delay","z":"48bbd268.e51fe4","g":"1c8ae54c.e53413","name":"","pauseType":"delay","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":900,"y":1220,"wires":[["fb65469f.14fd2"]]},{"id":"f8f78f36.e7a708","type":"ha-wait-until","z":"48bbd268.e51fe4","g":"1c8ae54c.e53413","name":"Wait until door is opened","server":"9f14629c.16082","outputs":1,"entityId":"binary_sensor.front_door_open_close_sensor","entityIdFilterType":"exact","property":"state","comparator":"is","value":"on","valueType":"str","timeout":0,"timeoutType":"num","timeoutUnits":"seconds","entityLocation":"","entityLocationType":"none","checkCurrentState":true,"blockInputOverrides":true,"x":430,"y":1220,"wires":[["3c8405b5.75e482"]]},{"id":"3c8405b5.75e482","type":"ha-wait-until","z":"48bbd268.e51fe4","g":"1c8ae54c.e53413","name":"Wait until door is closed","server":"9f14629c.16082","outputs":1,"entityId":"binary_sensor.front_door_open_close_sensor","entityIdFilterType":"exact","property":"state","comparator":"is","value":"off","valueType":"str","timeout":0,"timeoutType":"num","timeoutUnits":"seconds","entityLocation":"","entityLocationType":"none","checkCurrentState":true,"blockInputOverrides":true,"x":690,"y":1220,"wires":[["a528c20e.71ce8"]]},{"id":"20b990fe.068568","type":"debug","z":"48bbd268.e51fe4","g":"eb3e7517.630068","name":"Full debug to find attributes","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":360,"y":1700,"wires":[]},{"id":"cb163531.d23308","type":"switch","z":"48bbd268.e51fe4","g":"eb3e7517.630068","name":"Change by device","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"unlocked","vt":"str"},{"t":"eq","v":"locked","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":410,"y":1600,"wires":[["18776524.8f4353"],["d30a09b0.de6a68"]]},{"id":"1851c9f8.07e88e","type":"simpletime","z":"48bbd268.e51fe4","g":"eb3e7517.630068","name":"Time Now","mydate":true,"myymd":true,"myyear":true,"mymonth":true,"mymonthn":true,"mydom":true,"mydoy":true,"myday":true,"myhourpm":true,"myhour":true,"mytime":true,"mytimes":true,"myminute":true,"myminutes":true,"mysecond":true,"mymillis":true,"myepoch":true,"myrawdate":true,"mypm":true,"x":800,"y":1600,"wires":[["284eb9a6.7aa8ee"]]},{"id":"9cc1ace.1ca6cd","type":"simpletime","z":"48bbd268.e51fe4","g":"eb3e7517.630068","name":"Time Now","mydate":true,"myymd":true,"myyear":true,"mymonth":true,"mymonthn":true,"mydom":true,"mydoy":true,"myday":true,"myhourpm":true,"myhour":true,"mytime":true,"mytimes":true,"myminute":true,"myminutes":true,"mysecond":true,"mymillis":true,"myepoch":true,"myrawdate":true,"mypm":true,"x":800,"y":1660,"wires":[["a2ed941e.da0a3"]]},{"id":"18776524.8f4353","type":"api-call-service","z":"48bbd268.e51fe4","g":"eb3e7517.630068","name":"Increase by 1","server":"9f14629c.16082","version":1,"debugenabled":false,"service_domain":"counter","service":"increment","entityId":"counter.iosbadgecount","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":620,"y":1600,"wires":[["1851c9f8.07e88e"]]},{"id":"d30a09b0.de6a68","type":"api-call-service","z":"48bbd268.e51fe4","g":"eb3e7517.630068","name":"Increase by 1","server":"9f14629c.16082","version":1,"debugenabled":false,"service_domain":"counter","service":"increment","entityId":"counter.iosbadgecount","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":620,"y":1660,"wires":[["9cc1ace.1ca6cd"]]},{"id":"284eb9a6.7aa8ee","type":"api-call-service","z":"48bbd268.e51fe4","g":"eb3e7517.630068","name":"Send Notification Danalock Unlocked","server":"9f14629c.16082","version":1,"debugenabled":false,"service_domain":"notify","service":"all_devices","entityId":"","data":"{\"title\":\"Danalock Unlocked\",\"message\":\"Front door unlocked - {{myhourpm}}:{{myminute}}.{{mysecond}} {{mypm}} {{mydom}}/{{mymonthn}}/{{myyear}}\",\"data\":{\"push\":{\"thread-id\":\"danalock_unlocked\",\"badge\":\"{{states.counter.iosbadgecount.state}}\"}}}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1070,"y":1600,"wires":[[]]},{"id":"1d6f8c96.83c22b","type":"debug","z":"48bbd268.e51fe4","g":"1c8ae54c.e53413","name":"Unlock Debug","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":380,"y":1280,"wires":[]},{"id":"a2ed941e.da0a3","type":"api-call-service","z":"48bbd268.e51fe4","g":"eb3e7517.630068","name":"Send Notification Danalock Locked","server":"9f14629c.16082","version":1,"debugenabled":false,"service_domain":"notify","service":"all_devices","entityId":"","data":"{\"title\":\"Danalock Locked\",\"message\":\"Front door locked - {{myhourpm}}:{{myminute}}.{{mysecond}} {{mypm}} {{mydom}}/{{mymonthn}}/{{myyear}}\",\"data\":{\"push\":{\"thread-id\":\"danalock_locked\",\"badge\":\"{{states.counter.iosbadgecount.state}}\"}}}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1060,"y":1660,"wires":[[]]},{"id":"a10871ff.157138","type":"server-state-changed","z":"48bbd268.e51fe4","g":"eb3e7517.630068","name":"Danalock Changed","server":"9f14629c.16082","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"lock.front_door_lock","entityidfiltertype":"exact","outputinitially":true,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"x":170,"y":1640,"wires":[["20b990fe.068568","cb163531.d23308"]]},{"id":"b5f4b2b.2428e5","type":"delay","z":"48bbd268.e51fe4","g":"1c8ae54c.e53413","name":"","pauseType":"delay","timeout":"10","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1240,"y":1220,"wires":[["71be1352.b56944"]]},{"id":"71be1352.b56944","type":"api-current-state","z":"48bbd268.e51fe4","g":"1c8ae54c.e53413","name":"Check Locked Status","server":"9f14629c.16082","version":1,"outputs":2,"halt_if":"unlocked","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"lock.front_door_lock","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":1440,"y":1280,"wires":[["a528c20e.71ce8","b9439249.d0e858"],[]]},{"id":"f4583c67.7efc18","type":"simpletime","z":"48bbd268.e51fe4","g":"22ce619e.5c8996","name":"Time Now","mydate":true,"myymd":true,"myyear":true,"mymonth":true,"mymonthn":true,"mydom":true,"mydoy":true,"myday":true,"myhourpm":true,"myhour":true,"mytime":true,"mytimes":true,"myminute":true,"myminutes":true,"mysecond":true,"mymillis":true,"myepoch":true,"myrawdate":true,"mypm":true,"x":1880,"y":1260,"wires":[["fa592782.15e12"]]},{"id":"b9439249.d0e858","type":"api-call-service","z":"48bbd268.e51fe4","g":"22ce619e.5c8996","name":"Increase by 1","server":"9f14629c.16082","version":1,"debugenabled":false,"service_domain":"counter","service":"increment","entityId":"counter.iosbadgecount","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1700,"y":1260,"wires":[["f4583c67.7efc18"]]},{"id":"fa592782.15e12","type":"api-call-service","z":"48bbd268.e51fe4","g":"22ce619e.5c8996","name":"Send Failed To Lock Notification","server":"9f14629c.16082","version":1,"debugenabled":false,"service_domain":"notify","service":"all_devices","entityId":"","data":"{\"title\":\"Danalock Failed Lock\",\"message\":\"Front door failed to lock - {{myhourpm}}:{{myminute}}.{{mysecond}} {{mypm}} {{mydom}}/{{mymonthn}}/{{myyear}}\",\"data\":{\"push\":{\"thread-id\":\"danalock_failed_lock\",\"badge\":\"{{states.counter.iosbadgecount.state}}\"}}}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":2130,"y":1260,"wires":[[]]},{"id":"d58de43b.fc9108","type":"server-state-changed","z":"48bbd268.e51fe4","g":"386c77db.fe12d","name":"Cheryl Wi-Fi Connection","server":"9f14629c.16082","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.amplifi_cheryl_iphone_12_pro_max","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"x":170,"y":400,"wires":[[]]},{"id":"ec849ce9.823278","type":"server-state-changed","z":"48bbd268.e51fe4","g":"f68f9928.e9e058","name":"Danalock Unlocked","server":"9f14629c.16082","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"lock.front_door_lock","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"unlocked","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"x":150,"y":1420,"wires":[["e0036b68.a65b7","4da9b7b0.e911f8"],[]]},{"id":"518de0a4.be93","type":"api-call-service","z":"48bbd268.e51fe4","g":"f68f9928.e9e058","name":"Lock the door","server":"9f14629c.16082","version":1,"debugenabled":false,"service_domain":"lock","service":"lock","entityId":"lock.front_door_lock","data":"","dataType":"jsonata","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":980,"y":1400,"wires":[["4384adbd.fa9a2c"]]},{"id":"e0036b68.a65b7","type":"debug","z":"48bbd268.e51fe4","g":"f68f9928.e9e058","name":"Unlock Debug","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":380,"y":1480,"wires":[]},{"id":"4384adbd.fa9a2c","type":"delay","z":"48bbd268.e51fe4","g":"f68f9928.e9e058","name":"","pauseType":"delay","timeout":"10","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1160,"y":1400,"wires":[["b8770ca.81a70f"]]},{"id":"b8770ca.81a70f","type":"api-current-state","z":"48bbd268.e51fe4","g":"f68f9928.e9e058","name":"Check Locked Status","server":"9f14629c.16082","version":1,"outputs":2,"halt_if":"unlocked","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"lock.front_door_lock","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":1300,"y":1480,"wires":[["812ba674.19d34"],[]]},{"id":"4da9b7b0.e911f8","type":"delay","z":"48bbd268.e51fe4","g":"f68f9928.e9e058","name":"","pauseType":"delay","timeout":"5","timeoutUnits":"minutes","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":360,"y":1400,"wires":[["569d0765.dcc62"]]},{"id":"569d0765.dcc62","type":"api-current-state","z":"48bbd268.e51fe4","g":"f68f9928.e9e058","name":"Door status closed?","server":"9f14629c.16082","version":1,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"binary_sensor.front_door_open_close_sensor","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":580,"y":1400,"wires":[["812ba674.19d34"],[]]},{"id":"812ba674.19d34","type":"delay","z":"48bbd268.e51fe4","g":"f68f9928.e9e058","name":"","pauseType":"delay","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":800,"y":1400,"wires":[["518de0a4.be93"]]},{"id":"7b2a46d5.3c702","type":"server-state-changed","z":"48bbd268.e51fe4","g":"587ec5cd.31bd2c","name":"James Home Switch","server":"9f14629c.16082","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.hk_presence_james","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"x":150,"y":220,"wires":[["aa885953.460048","300a76e9.48a96a"]]},{"id":"300a76e9.48a96a","type":"switch","z":"48bbd268.e51fe4","g":"587ec5cd.31bd2c","name":"Arriving or Leaving","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"connected","vt":"str"},{"t":"eq","v":"disconnected","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":390,"y":180,"wires":[["6d9bc30e.301184"],["aae03745.2c5b2"]]},{"id":"aae03745.2c5b2","type":"api-call-service","z":"48bbd268.e51fe4","g":"587ec5cd.31bd2c","name":"James Leaving Lock the door","server":"9f14629c.16082","version":1,"debugenabled":false,"service_domain":"lock","service":"lock","entityId":"lock.front_door_lock","data":"","dataType":"jsonata","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":650,"y":220,"wires":[[]]},{"id":"6d9bc30e.301184","type":"api-call-service","z":"48bbd268.e51fe4","g":"587ec5cd.31bd2c","name":"Unlock the door","server":"9f14629c.16082","version":1,"debugenabled":false,"service_domain":"lock","service":"unlock","entityId":"lock.front_door_lock","data":"","dataType":"jsonata","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":760,"y":120,"wires":[["59f6d36b.4b14cc"]]},{"id":"8b0c9caf.68f5f8","type":"delay","z":"48bbd268.e51fe4","g":"587ec5cd.31bd2c","name":"","pauseType":"delay","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1500,"y":60,"wires":[["df7a57eb.03483"]]},{"id":"59f6d36b.4b14cc","type":"ha-wait-until","z":"48bbd268.e51fe4","g":"587ec5cd.31bd2c","name":"Wait Until Front Door Open","server":"9f14629c.16082","outputs":2,"entityId":"binary_sensor.front_door_open_close_sensor","entityIdFilterType":"exact","property":"state","comparator":"is","value":"on","valueType":"str","timeout":"10","timeoutType":"num","timeoutUnits":"minutes","entityLocation":"","entityLocationType":"none","checkCurrentState":true,"blockInputOverrides":true,"x":1000,"y":100,"wires":[["fbae4b12.f63148"],["df7a57eb.03483"]]},{"id":"df7a57eb.03483","type":"api-call-service","z":"48bbd268.e51fe4","g":"587ec5cd.31bd2c","name":"James Ariving Lock the door","server":"9f14629c.16082","version":1,"debugenabled":false,"service_domain":"lock","service":"lock","entityId":"lock.front_door_lock","data":"","dataType":"jsonata","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1520,"y":180,"wires":[[]]},{"id":"fbae4b12.f63148","type":"ha-wait-until","z":"48bbd268.e51fe4","g":"587ec5cd.31bd2c","name":"Wait Until Front Door Closed","server":"9f14629c.16082","outputs":1,"entityId":"binary_sensor.front_door_open_close_sensor","entityIdFilterType":"exact","property":"payload","comparator":"is","value":"off","valueType":"str","timeout":"0","timeoutType":"num","timeoutUnits":"minutes","entityLocation":"","entityLocationType":"none","checkCurrentState":true,"blockInputOverrides":true,"x":1280,"y":60,"wires":[["8b0c9caf.68f5f8"]]},{"id":"aa885953.460048","type":"debug","z":"48bbd268.e51fe4","g":"587ec5cd.31bd2c","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":350,"y":140,"wires":[]},{"id":"9f14629c.16082","type":"server","name":"Home Assistant","legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
Awesome, thanks. Need to check that out.
After long investigation, bought Danalock V3-BTZE my self. I regret it.
The lock can not send Locked/Unlocked status trough Z-Wave or battery status.
Found the information here:
[Product Configuration Capabilities]
The DanaLock is good only if you are planing to use it with bluetoot and not in any automations
