Hi
I started out with danalock z-wave but due to terrible signal strength i sent it back to the store and bought a danalock v3 zigbee. That works just fine as my whole house is zigbee.
I added it just fine to conbee2 but and i can lock/unlock and see current lock status, but im having trouble getting any other sensors/entities from the lock. While using z-wave js UI i could configure pretty much everything in the lock, including getting battery status and setting codes etc.
How do i go about getting more information from the lock using deconz/zigbee?
How do i go about configuring codes etc through zigbee?
Ive searched the internet but there are no guides or instructions anywhere.
ZHA, Zigbee2mqtt?
Is it on the Blakadder website as working?
Deconz!
What is blakadder website?
Replying to myself here. Doing some research online tells me should probably kill deconz and go with ZHA or zigbee2mqtt to get more entities?
My preferred choice is zigbee2mqtt, but depending on how many zigbee devices you have migrating might be quite some work. (I have 110). So if that is your situation, maybe find a cheap support additional zigbee dongle and set up zigbee2mqtt with that to try it out. Or find a user here that has it already setup with zigbee2mqtt
The support for Danalock by Deconz is very poor, it took a long time to get anything and it hasn’t really moved forwards very much. Switch to zigbee2mqtt and you will have a much better experience.
