I have three Danfoss LC13 (MT02650) thermostats in my home assistant network. The device configuration includes a temperature control and a temperature sensor.
Currently, I am trying to automate and optimise the heating. The supply temperature (Vorlauftemperatur) for the heaters is probably about 40° - 60° C for the flat. For heating the target temperature is set to 28° C and the valve opens fully. When the external temperature sensor in the room reaches a trigger temperature the target temperature is set to 19° C and the value closes. At this point, the temperature sensor on the thermostat can measure something like 25° C depending on the cycle length.
Is there any better to automate this? Maybe, somebody does have experience with the thermostat?
References
