App is not telling anything, and unit flashing two green leds. Rebooted the unit, and back functioning.
So need to figure out how to write the correct codes to the correct registers on the unit, so shift between “auto”, “manual”, as well as “summer” and “bypass auto” modes.
Also got access to the PC Tool, for further adjustment of set values.
I have coded my own full demand control of HCV400, based on night / outdoor / home signals from IHC, whether the bath is in use (IHC signal), and demand control via indoor climate sensors on VOC and CO2 (Airthings Wave Plus) and RH via the built-in sensor , as well as whether patio doors are open in summer (switch to extraction only).
My system only runs auto at night and when the house is empty. Fan 1 speed only when VOC, CO2 and Humidity are very low, as VOC and CO2 rise too fast when running fan1 at standard. It runs 2 by default, and adjust to 3 respectively 4 depending humidity, CO2 and VOC levels.
I mailed Dantherm a while ago to get more info on the modbus configuration. They sent me a full document with all registers. Maybe this can be of some use to you?
Can you explain how you manage to communicate (give instructions to the HCV400)?
Because I would like to do the same as you in terms of control (door open for summer, CO2 level monitored in important rooms).
In terms of power consumption, there is a big difference between levels 2 and 3. I can’t find any automatic programs that correspond to our needs.
Indeed, level 1 is not sufficient at all when the house is not empty.
And I can only use the application locally … At the moment, the VPN on my phone does not allow me to connect to the HCV400 via their application.
Following the procedure, I managed to connect to the HCV300, read the values, change them via the tool indicated.
BUT I can’t manage to make program 11 active, the one that is supposed to be custom … I see it come changed as it should via the smartphone app but when I ask it to switch to program 11, the fan runs at level 3 as the default value.
If I turn everything off, wait a few minutes and restart the HCV300, what I have done has disappeared, is not saved and defaults to program level 11 (ie level 3 all the time).
Did you manage to customize program 11 and make it active?
For me, this is an intermediate step (to make it more suitable for our needs) before dynamically changing the fan speed.
I tried to integrate all functions of the Dantherm app in Home Assistant. It’s not a full integration through HACS, only several automations and scripts to make the dashboard do what I want.
There is a tool available called Modbus Poll. It’s costly software, but I mailed the developers and explained my DIY use of their tool and they gave me a great discount. I do believe there is also a trial version available.
Hi.
I dont have alot of experience with yaml in home assistant. But im happy to see that this work is being done. I was a Dantherm technician, and technical supporter, and im actually the one that sent the modbus pdf to @arnocl .
If i can help in any way please let me know, i have access to the pc tool - admin if that helps.
@arnocl : I’m aware of modbus poll, but the reason for the tool is not connecting or finding new registers. I succeeded in connecting/reading the values with the information in this thread. Thanks anyway for sharing the received pdf/information
I’m looking for the pc tool because I have/had some issues with the configuration of my unit. When the dantherm unit was installed and calibrated, the installer used the tool to increase throughput/rpm of the fans, in order to meet regulations. The default throughput was only little to low, but the fans were put to max power anyway. Afterwards all ceiling in-/out-take nozzles were closed in order to get the desired airflow. Some days later, I realized it’s like driving a bike/car with the brakes put on. It’s additional power consumption and wear just to get the correct airflow.
It would be better for the device and the power consumption if I could reduce the airflow-resistance as well as rpm’s of the fans.
In the meantime, I accepted the situation because currently I don’t have the equipment any more to properly measure/adjust the airflow of the intake-outlets, so I won’t be able to do it properly anyways (at least at the moment).
@Liquidsmoke : I don’t know if you can or are allowed to share the tool. When I buy a device, I’m used to collect all possible tools for managing, just in case I need them one day, or when they would be removed from the public internet. If you cannot share this information in public, you can send me a PM
Bonjour à tous, je vous rejoins car petit nouveau dans HA, j’ai une DF Hcv 700 dantherm, je voulais savoir si votre configuration fonctionnerait pour moi aussi ? J’aurais besoin d’un peu d’aide au début pour comprendre comment vous mettez le modbus sur HA, je suis connecté en câble avec une ip fixe, il y a t’il un hacs modbus à télécharger avant ? Si quelqu’un peut m’aider un peu. Merci
New to HA as well. I would like to integrate my unit HCV 400 P1 but unfortunately I lack the technical skills. I added the configuration into configuration.yaml but that is where I got stuck. I’m unsure what to do next. Can someone please share a tutorial for a complete noobs or direct me to a source, that’ll show the basics that would help me understand how to do it? Many thanks
