Got some errors from this one but really nice work, helped me alot, is there missing something in scripts?
Also don’t think Vertical Stack In Card can be installed atm I modded it to work without.
“The automation “Dantherm - Auto Schedule” (automation.dantherm_auto_schedule ) has an action that calls an unknown service: script.dantherm_automatische_modus .”
The script.dantherm_automatische_modus should be script.dantherm_demand_mode
Hope this helps. I guess there can be some remaining problems, if I find the time and there is an interest I’ll see to revise the code and make a thorough English translation.
hello Ladies and Gentlemen,
I am totally new to HA with a recent install on rpi4.
i’m very much interested in plugin my HCV700 into my HA dashboard but i’ve never done any advanced configuration of the system yet. (long IT background, but several years ago …)
Can you help me getting the required prerequisites and resources (files, pieces of code, instructions, …) to make it happen ?
can you tell us how to integrate your files into home assistant. I’m new to it. the values go up but impossible to interact with the dantherm unit
THANKS
The contents of automations.yaml and scripts.yaml sjould be added to the files of the same name that are already present in your installation.
The contents of dantherm.yaml should be added to your existing configuration.yaml
Finally the contents of dashboard.yaml should be added into a dashboard.
If i take the dashborad.yaml, and try make a card. I get an error about no type used. But i tried all kind of things and just cant get the dashboard to work
Hi.
I have been working on a HACS custom intergration for a while now and just wanted to share a picture of it.
This is the danish translation but english is also available.
I’m also seaching for some, willing to test it out, maybe on a spare instalation of Home Assistant in order not to mess something up Preferably also on another units than the HCV400 P2. The documentation available in this post, which this integration is based upon, suggests it will work with a list of other units.
