Hi Folks - With DarkSky slated to close down the API in the near future (March 2023, I think?), what would you consider the best alternative for basic “current weather” information? I mostly use it for a tile on my dashboards, not really in any automations, for example:
I’m in the US if that helps zero in on a choice. I don’t know if the OpenWeatherMap provides the same kind of info, so I thought I’d reach out here first.
I’m going to install Pirate Weather. I was trying to avoid it because it HACS, but many of the other weather integrations have annoying bugs. I listed some below but I think there are more.
met.no - doesn’t show todays forecast. Also if the servers are high load HASS is the first to get kicked off.
open-meteo - time offset problems so the data is always wrong.
I found myself here because with HA core 2023.3.0, the Dark Sky card broke completely and doesn’t show anything. I’ve been using Pirate Weather for at least a year… however, I discovered if I removed the deprecated Dark Sky integration from HACS, it takes my Pirate Weather entities with it! I was left with no weather entities at all.
My plan was to try out the Platinum Weather Card, so I’ve rolled back an update or two and I have my entities restored. I’ll try installing that and plugging the Pirate Weather entities into it… or I’ll just go back to the old Custom Animated Weather Card.
I guess if I want to use my Pirate Weather entities, I just have to ignore this HACS notification:
EDIT: It was not the removal of the archived Dark Sky integration that killed my Pirate Weather entities… it was the upgrade to 2023.3.0! Looks like I’ll need to find a new source for weather data, unless re-installing Pirate Weather through HACS restores those entities.
EDIT 2: yeah… after upgrading to 2023.3.0 and installing Pirate Weather, the Dark Sky entities don’t come back. My weather entities and dashboard are dead.
EDIT 3: Fixed. I never installed the Pirate Weather integration, because I didn’t have to. I was using the old DS integration and PW was feeding it sensor data. I’ve configured the PW integration, and now I’ve got a ton of entities to play with.
I got it working this afternoon–for some reason, I had to delete the Platinum Weather Card repository and reinstall it. Once I did, I put in mostly (if not all) native Pirate Weather sensors and it’s working well.
I tried Pirate Weather as an alternative to Dark Sky, but I’m finding it to be significantly off in temperature (highs are low, and o/n lows are high - range is compressed).
What are the next best alternatives to Dark Sky and Pirate Weather, that people find satisfactory?
