Hello, and thank you in advance for any assistance you provide. I have (had?) the Dark Sky Sensor configured and working for some time. Yesterday, Dark Sky Sensor no longer shows up? I see it in “States” and I can select it when I add it as a new entity, but there is no data being shown. I reset my API code and that hasn’t made a difference. It seems to have just stopped working. Any ideas how I can get the data to start showing?
I am running the latest version (0.103.5) on a RPi 3B+. Could the update have caused this?
Do you see any errors under Sidebar -> Developer Tools -> Logs?
Can you show a picture of the entitiy in Sidebar -> Developer Tools -> States?
No, no errors that I can see. Here are the screens you asked for:
Thank you for looking at this
And what is your issue exactly? The sensors are there and they have a state. Where are you missing the data?
Yes, the sensors are there and so is the state; however, the data will not show up in any entity card I create (it used to). Here is a picture of the entity card. It has a label for Dark Sky, but no data
Further to this, the issue is Dark Sky Sensor. The regular Dark Sky works fine
SOLVED!
I cleared my cache (first time didn’t work so I went further back). Restarted and it appears everything is working now.
Thank you so much for your help with this
