Dark Theme missing something
I have this Dark them listed below and after I upgraded to 108.3 I lost the menu bar.
Found a thread about how to fix that and it is the last section on the listing below.
But have had a issue for a while with not being able to see anything when clicking
on Conifguration/Devices or Entities and most things in that menu.
Anyone know what is missing from this theme.
Thanks…
midnight:
  # Main colors
  primary-color: '#5294E2'                                                        # Header
  accent-color: '#E45E65'                                                         # Accent color
  dark-primary-color: 'var(--accent-color)'                                       # Hyperlinks
  light-primary-color: 'var(--accent-color)'                                      # Horizontal line in about
  # Text colors
  primary-text-color: '#FFFFFF'                                                   # Primary text colour, here is referencing dark-primary-color
  text-primary-color: 'var(--primary-text-color)'                                 # Primary text colour
  secondary-text-color: '#5294E2'                                                 # For secondary titles in more info boxes etc.
  disabled-text-color: '#7F848E'                                                  # Disabled text colour
  label-badge-border-color: 'green'                                               # Label badge border, just a reference value
  # Background colors
  primary-background-color: '#383C45'                                             # Settings background
  secondary-background-color: '#383C45'                                           # Main card UI background
  divider-color: 'rgba(0, 0, 0, .12)'                                             # Divider
  # Table rows
  table-row-background-color: '#353840'                                           # Table row
  table-row-alternative-background-color: '#3E424B'                               # Table row alternative
  # Nav Menu
  paper-listbox-color: 'var(--primary-color)'                                     # Navigation menu selection hoover
  paper-listbox-background-color: '#2E333A'                                       # Navigation menu background
  paper-grey-50: 'var(--primary-text-color)'
  paper-grey-200: '#414A59'                                                       # Navigation menu selection
  # Paper card
  paper-card-header-color: 'var(--accent-color)'                                  # Card header text colour
  paper-card-background-color: '#434954'                                          # Card background colour
  paper-dialog-background-color: '#434954'                                        # Card dialog background colour
  paper-item-icon-color: 'var(--primary-text-color)'                              # Icon color
  paper-item-icon-active-color: '#F9C536'                                         # Icon color active
  paper-item-icon_-_color: 'green'
  paper-item-selected_-_background-color: '#434954'                               # Popup item select
  paper-tabs-selection-bar-color: 'green'
  # Labels
  label-badge-red: 'var(--accent-color)'                                          # References the brand colour label badge border
  label-badge-text-color: 'var(--primary-text-color)'                             # Now same as label badge border but that's a matter of taste
  label-badge-background-color: '#2E333A'                                         # Same, but can also be set to transparent here
  # Switches
  paper-toggle-button-checked-button-color: 'var(--accent-color)'
  paper-toggle-button-checked-bar-color: 'var(--accent-color)'
  paper-toggle-button-checked-ink-color: 'var(--accent-color)'
  paper-toggle-button-unchecked-button-color: 'var(--disabled-text-color)'
  paper-toggle-button-unchecked-bar-color: 'var(--disabled-text-color)'
  paper-toggle-button-unchecked-ink-color: 'var(--disabled-text-color)'
  # Sliders
  paper-slider-knob-color: 'var(--accent-color)'
  paper-slider-knob-start-color: 'var(--accent-color)'
  paper-slider-pin-color: 'var(--accent-color)'
  paper-slider-active-color: 'var(--accent-color)'
  paper-slider-container-color: 'linear-gradient(var(--primary-background-color), var(--secondary-background-color)) no-repeat'
  paper-slider-secondary-color: 'var(--secondary-background-color)'
  paper-slider-disabled-active-color: 'var(--disabled-text-color)'
  paper-slider-disabled-secondary-color: 'var(--disabled-text-color)'
  # Google colors
  google-red-500: '#E45E65'
  google-green-500: '#39E949'
##Sidebar
  sidebar-background-color: "var(--paper-listbox-background-color)"
  sidebar-icon-color: "rgba(255, 255, 255, 0.70)"
  sidebar-selected-icon-color: "var(--primary-color)"
  sidebar-selected-text-color: "var(--primary-text-color)"
  sidebar-text-color: "var(--primary-text-color)"
  slider-bar-color: "var(--disabled-text-color)"
  slider-color: "var(--primary-color)"
  slider-secondary-color: "var(--light-primary-color)"
That solved it.
Thanks for the help!
No worries. If you mark it solved it helps others when searching.
Is that the Solution check box?
Looks like you already did it.
Thanks I will do that on future posts.
Nope only you (The question asker) or a mod can do it. Click the check box under the post with the solution, it will turn green.
Ok just clicked it on the fix.
Hope that helps someone else.
