Hi.
I tried adding the following Dark Sky conditions to configuration.yaml but get an error:
weather:
- platform: darksky
api_key: [theapikey]
monitored_conditions:
- summary
- temperature
- apparent_temperature
- uv_index
- precip_probability
- precip_accumulation
- humidity
- ozone
- pressure
- wind_bearing
- wind_speed
- visibility
mode: daily
Check Config shows:
Configuration invalid
Invalid config for [weather.darksky]: [monitored_conditions] is an invalid option for [weather.darksky].
Check: weather.darksky->monitored_conditions. (See ?, line ?).
Please check the docs at https://home-assistant.io/integrations/darksky/
If I remove monitored_conditions from configuration.yaml everything works well.
TIA
