I am aware that Darsky was acquired by Apple as noted here, although it should still be available to existing users like myself.
However now if I check the config it keeps going in a loop.
I isolated the issue by commenting everything in my config and uncommenting bit by bit while performing a config check at each step and that led to Darsky being the problem.
Darksky free trial states that 1000 calls/day (snapshot from Darsky dashboard below) are allowed and I am definitely below that threshold so that can’t be the issue.
Not sure what the issue was but darksky came back to normal. @123 thanks for the tip I double checked to make sure it only does 1call/hour just in case.
