I’m a new user with Hassio 86.2 installed.
Mixed results to date - mostly learning the interfaces. Currently trying to make an automation to switch on my pond heater when it gets below freezing (and off when it gets above).
Using one of the examples as a guide, I coded the following:
platform: numeric_state
entity_id: weather.darksky
value_template: "{{ state.attributes.temperature }}"
# Can be a positive or negative number
below: 31.0
service: switch.turn_on
entity_id: switch.pond_outlet_power
- id: '1549154823486'
alias: "Pond heater when above freezing"
above: 32.0
service: switch.turn_off
It’s gone below freezing and its not switching. I’m more interested in how to debug than in the syntax i’m sure I have wrong.
Here is the json response I get back from Darksky
{“latitude”:xx.873,“longitude”:-xx.239,“timezone”:“America/Toronto”,“currently”:{“time”:1549384945,“summary”:“Mostly Cloudy”,“icon”:“partly-cloudy-day”,“nearestStormDistance”:207,“nearestStormBearing”:195,“precipIntensity”:0,"precipProbability":0,“temperature”:30.56,“apparentTemperature”:19.26,“dewPoint”:22.75,“humidity”:0.72,“pressure”:1019.31,“windSpeed”:16.32,“windGust”:21.48,“windBearing”:320,“cloudCover”:0.9,“uvIndex”:2,“visibility”:9.56,“ozone”:261.2},“minutely”:{“summary”:“Mostly cloudy for the hour.”,“icon”:“partly-cloudy-day”,“data”:[{“time”:1549384920,“precipIntensity”:0,“precipProbability”:0},
So the temperature is 30.56 (it was > 32).
I’m pretty sure I have specified my switch entity right.
I’m not sure about the value template syntax.
I know i’m receiving the darksky data properly since it shows in the home page. One difference is that the temp shows as celsius - but I presume that;s just home assistant translating it to my preference (I would assume that the automation is still using the raw, untranslated Fahrenheit temp that darksky sends).
Any help or meta-help appreciated.
