Hi guys,
I’m trying to setup the DarkSky sensors and I’m using this in my config:
- platform: darksky
api_key:
monitored_conditions:
- summary
- precip_type
- precip_intensity
- precip_probability
- precip_accumulation
- temperature
- apparent_temperature
- dew_point
- wind_speed
- wind_bearing
- cloud_cover
- humidity
- pressure
- visibility
- ozone
- minutely_summary
- hourly_summary
- daily_summary
- temperature_high
- temperature_low
- apparent_temperature_high
- apparent_temperature_low
- precip_intensity_max
- uv_index
And my sensors:
weather_temperature:
entities:
- sensor.dark_sky_temperature
- sensor.dark_sky_temperature_high
- sensor.dark_sky_temperature_low
- sensor.dark_sky_apparent_temperature
- sensor.dark_sky_apparent_temperature_high
- sensor.dark_sky_apparent_temperature_low
but for some reason those sensors aren’t showing, log files say nothing about those sensors, yet they don’t show up on my dashboard. This applies for dark_sky_temperature_high, dark_sky_apparent_temperature, dark_sky_apparent_temperature_high and dark_sky_apparent_temperature_low.
I’m I using the wrong syntax for those?
high is daytime_high_temperature
low is overnight_low_temperature
Are you sure? I can’t really make that out from the code here or docs here .
Yes
sensor.dark_sky_daytime_high_temperature
sensor.dark_sky_overnight_low_temperature
With those monitored conditions, if you look in the dev tools > states you will see all the darksky sensors it creates
Interesting! I does work yes!
Updated my config to:
entities:
- sensor.dark_sky_daytime_high_temperature
- sensor.dark_sky_overnight_low_temperature
- sensor.dark_sky_daytime_high_apparent_temperature
- sensor.dark_sky_overnight_low_apparent_temperature
And they show now, thanks!
ih8gates
(Scott Reston)
December 5, 2018, 3:23pm
6
Running .83.2, I’ve stopped getting high and low temps. I was using temperature_high/temperature_low for monitored_conditions.
As recommended above, I tried daytime_high_temperature/overnight_low_temperature but that causes an error in HA saying that those are invalid conditions.
Is anyone using .83.2 and still getting highs/lows? Didn’t see anything in breaking changes.
Dixey
December 5, 2018, 4:59pm
7
I had the same issues. With guidance from another user here, I modified my .yaml files as follows:
sensors.yaml:
# Weather
- platform: darksky
api_key: !secret darksky_api
latitude: 29.300130
longitude: -94.795850
update_interval: "00:15"
forecast:
- 0
- hourly_summary
- temperature
- temperature_high
- temperature_low
- cloud_cover
- precip_type
- precip_intensity
- wind_speed
- wind_bearing
- wind_gust
- humidity
- dew_point
- uv_index
- visibility
- ozone
- pressure
- nearest_storm_distance
- nearest_storm_bearing
ui-lovelace.yaml
- type: vertical-stack
cards:
- type: entities
title: Island Weather Conditions
show_header_toggle: false
entities:
- type: divider
- type: entity
entity: sensor.galveston_hourly_summary
- type: divider
- type: entity
entity: sensor.galveston_temperature
- type: entity
entity: sensor.galveston_overnight_low_temperature_0
- type: entity
entity: sensor.galveston_daytime_high_temperature_0
- type: entity
entity: sensor.galveston_apparent_temperature
- type: entity
entity: sensor.galveston_dew_point
- type: entity
entity: sensor.galveston_pressure
- type: entity
entity: sensor.galveston_cloud_coverage
- type: entity
name: Rain Intensity
entity: sensor.galveston_precip_intensity
- type: entity
entity: sensor.galveston_wind_speed
- type: entity
entity: sensor.galveston_wind_gust
- type: entity
name: Wind Coming From the
icon: mdi:compass
entity: sensor.galveston_wind_dir
- type: entity
entity: sensor.galveston_nearest_storm_distance
- type: entity
name: Nearest Storm Bearing
icon: mdi:compass
entity: sensor.galveston_nearest_storm_dir
- type: entity
entity: sensor.galveston_humidity
- type: entity
entity: sensor.galveston_ozone
- type: entity
entity: sensor.galveston_uv_index
note the _0 appended to the sensor entity names you used to have. The 0 throughout means today.
ih8gates
(Scott Reston)
December 5, 2018, 6:31pm
8
Thanks. The “forecast” option was what I was missing. Once I added that, I started getting the highs/lows with the _0 suffix. Thanks.
That was a change in 0.83 adding the 0. It pays to read the release notes!
Been kicking myself over that at lunch, as Wunderground keeps failing to get data.
