Dashboard `500 Internal Server Error`
Hi
I moved from a vm based has / appdaemon to HASSIO
Installed appdaemon via the hassio web ui. Started ok and i can see the hello dashboard
copied my dashboard file over, pretty basic really and references the same entities, and i get a server error when loading it
`Server got itself in trouble`
I tried to add just the clock into the hello.dash, and i get the same error on that one too!
Not sure where to start, thought being an automated install it would work.
Here is the log - https://pastebin.com/LfuqZZX0
you have things inside your dashboard that are not right in yaml.
maybe due to copy pasting (wrong characters), or indention errors.
