Dashboard Card for RGBW Lights on Local Tuya
I’ve got several Lumary Smart RGB Tunable White Ultra-thin Lights that I’m setting up under Local Tuya. I’ve tried a couple of light cards and can turn them on/off and change the colors without any issues. Is there a way to integrate controlling the other fancy things that the Tuya app controls like the Scenes, Rhythms, Power-On Behavior, etc?
Thanks!
Hi
did you have any luck with this? im trying to work out how to switch back to just white, my driver is a rgbw driver and not a cct and cant see any options for just white?
thanks
No, I didn’t try for very long though. I found a couple of folks who pre-programmed colors into cards, but I really want the novelty of programming that comes with the Smart Life app and it’s not worth it to me to spend time right now trying to duplicate that just to get it off the native app.
For your problem though, you should be able to setup a color for white, with RGB values.
