Dashboard Card for Time and Date
Is this even possible for a super newbie like me…? I have not dabbled yet in YAML just so you know. The tablet dash board I’m coming from had that and more so I’m working with base Lovelace and it’s not bad but my wife really misses the time and date.
Thanks much
If you install HACS, you can see a few clock cards there
Else indeed via a yaml-type approach, example
Simple Lovelace Date card - Configuration / Frontend - Home Assistant Community (home-assistant.io)
I did find one that looks good, it’s called Digital Clock but the font is just too small to view from anything but up close. Sure wish there was away to edit font size and color
have a look here
Height for digital clock · Issue #23 · wassy92x/lovelace-digital-clock (github.com)
Just to add, the hand entered code provided above works great and you can tweak it for other size options and more. Thanks much…
great :slight_smile: …please mark one of my posts then as ‘solution’ so people can use this for future refrence
I just noticed you cross posted, not as it should be tbh…please avoid in the future
