Dashboard cards not displaying unless I reset the frontend cache often
I have two cards on a dashboard that are acting up. The first is a grid to display two Honeywell / Residio thermostats. The second is a vertical stack to display an image from Windy.com and the wind direction.
This is what the dashboard is supposed to look like:
Here is the YAML for the first card:
square: true
type: grid
cards:
  - type: thermostat
    entity: climate.hallway
  - type: thermostat
    entity: climate.upstairs
columns: 2
Here is the YAML for the second card:
type: vertical-stack
cards:
  - type: iframe
    url: >-
      https://embed.windy.com/embed.html?type=map&location=coordinates&metricRain=default&metricTemp=default&metricWind=default&zoom=5&overlay=wind&product=ecmwf&level=surface&lat=41.3&lon=-71.9&message=true
    aspect_ratio: 50%
  - type: custom:compass-card
    indicator_sensors:
      - sensor: weather.pirateweather
        attribute: wind_bearing
        indicator:
          image: arrow_inward
There are other cards on the dashboard that always display correctly.
The issue is that in the Companion App as well as on Chrome on a Windows 11 laptop, those cards often do not display at all. Here is what the dashboard looks like most of the time:
On my iPhone and iPad, if I reset the frontend cache they reappear. On Windows, it seems reloading the webpage gets them to show up.
Any ideas as to what’s going on? In case this might be due to some sort of strange interaction with the other cards, the following is the YAML for all of the cards on that view of the dashboard:
  - title: Climate
    path: climate
    cards:
      - square: true
        type: grid
        cards:
          - type: thermostat
          - type: thermostat
        columns: 2
      - type: vertical-stack
        cards:
          - type: iframe
            url: >-
            aspect_ratio: 50%
            indicator_sensors:
                indicator:
                  image: arrow_inward
      - show_current: true
        show_forecast: true
        type: weather-forecast
        entity: weather.openweathermap
        forecast_type: daily
        name: Stonington, CT OWM
        show_forecast: true
        entity: weather.pirateweather
        forecast_type: hourly
        forecast_slots: 8
      - type: custom:horizon-card
        cards:
          - type: horizontal-stack
            cards:
              - type: entity
                entity: sun.sun
                attribute: azimuth
                state_color: true
              - type: entity
                entity: sun.sun
                attribute: elevation
                state_color: true
          - type: entity
            entity: sensor.solar_noon
            icon: mdi:clock-time-eight-outline
            state_color: true
        title: Sun Position
      - type: gauge
        entity: sensor.airnow_air_quality_index
        min: 0
        max: 350
        needle: true
        segments:
            color: '#43a047'
            color: '#fcff33'
            color: '#ffa233'
            color: '#ff3368'
            color: '#c433ff'
            color: '#bb0d3a'
        cards:
          - type: gauge
            entity: sensor.smart_irrigation_north
            name: North 76 sq ft
            needle: true
            max: 1800
            min: 0
            severity:
              green: 0
              yellow: 600
              red: 1200
          - type: gauge
            entity: sensor.smart_irrigation_south
            name: South 124 sq ft
            needle: true
            max: 1800
            min: 0
            severity:
              green: 0
              yellow: 600
              red: 1200
        title: Watering Times
        cards:
          - type: custom:auto-entities
            filter:
              include:
                - options: {}
                  state: Upstairs
            card:
              type: custom:flex-table-card
              columns:
                - name: Upstairs
                  data: friendly_name
                - name: >-
                    <ha-icon icon="mdi:thermometer"
                    style=color:green;></ha-icon>
                  data: temperature
                - name: >-
                    <ha-icon icon="mdi:water-percent"
                  data: humidity
            filter:
              include:
                - options: {}
                  state: Downstairs
            card:
              columns:
                - name: Downstairs
                  data: friendly_name
                - name: >-
                  data: temperature
                - name: >-
                  data: humidity
            filter:
              include:
                - options: {}
                  state: Outside
            card:
              columns:
                - name: Outside
                  data: friendly_name
                - name: >-
                  data: temperature
                - name: >-
                  data: humidity
    type: custom:masonry-layout
A few thoughts. 1. Do you need the custom:masonry-layout? Looks to me sections would be fine with the rest of your card layouts, and the less reliance on custom cards the easier to work out issues like this. 2. Check for errors in console/logs. which may guide you.
