Dashboard - difficulty splitting up files
I’m trying to split up my dashboard into more manageable chunks. I believe I have a spacing/indentation issue but can’t seem to solve it. Here’s the start of my attempt to split:
tablet-split.yaml
  - title: Tablet-Test
    panel: true
    cards:
      - type: picture-elements
        image: /local/floorplan/home.png
        elements:
          - !include /config/dashboards/floorplans/fo_floorplan.yaml
          - !include /config/dashboards/elements/fo_elements.yaml
fo_floorplan.yaml
# FRONT OFFICE
- type: image
  entity: light.front_office_overhead_lights_dimmer
  style:
    left: 50%
    top: 50%
    width: 100%
    mix-blend-mode: lighten
    filter: >-
      ${ "hue-rotate(" +
      (states[‘light.front_office_overhead_lights_dimmer’].attributes.hs_color
      states[‘light.front_office_overhead_lights_dimmer’].attributes.hs_color[0]
      : 0) + "deg)"}
    opacity: >-
      ${states[‘light.front_office_overhead_lights_dimmer’].state === 'on' ?
      (states[‘light.front_office_overhead_lights_dimmer’].attributes.brightness
      / 255) : '0'}
  state_image:
    "on": /local/floorplan/home_fo_overhead.png
    "off": /local/floorplan/home.png
  tap_action:
    action: none
- type: image
  entity: light.front_office_desk_lamp
  style:
    left: 50%
    top: 50%
    width: 100%
    filter: >-
      ${ "hue-rotate(" +
      (states[‘light.front_office_desk_lamp’].attributes.hs_color ?
      states[‘light.front_office_desk_lamp’].attributes.hs_color[0] : 0) +
      "deg)"}
    opacity: >-
      ${states[‘light.front_office_desk_lamp’].state === 'on' ?
      (states[‘light.front_office_desk_lamp’].attributes.brightness / 255) :
      '0'}
  state_image:
    "on": /local/floorplan/home_fo_desk_lamp.png
  tap_action:
    action: none
- type: image
  entity: light.front_office_fan_light
  style:
    left: 50%
    top: 50%
    width: 100%
    filter: >-
      ${ "hue-rotate(" +
      (states[‘light.front_office_fan_light’].attributes.hs_color ?
      states[‘light.front_office_fan_light’].attributes.hs_color[0] : 0) +
      "deg)"}
    opacity: >-
      ${states[‘light.front_office_fan_light’].state === 'on' ?
      (states[‘light.front_office_fan_light’].attributes.brightness / 255) :
      '0'}
  state_image:
    "on": /local/floorplan/home_fo_fan.png
  tap_action:
    action: none
fo_elements.yaml:
# FRONT OFFICE
- type: state-icon
  icon: mdi:alarm-light
  entity: light.living_room_overhead_lights_dimmer
  style:
    left: 75%
    top: 15%
    opacity: 75%
    transform: scale(3.0,3.0)
    color: red
  hold_action:
    action: more_info
  double_tap_action:
    action: toggle
I can’t read the error message as it’s too far to the left, but I think it’s an indentation error? I removed the ‘-’'s from the files it loads since the !include itself is in a list but that didnt’t work… any idea how to figure out what’s causing it?
I don’t believe you can include, inside a list, files that themselves are a list, it doesn’t merge into a flat list.
If you had fo_floorplan.yaml and fo_elements.yaml inside a single directory, I think you could merge like so:
elements: !include_dir_merge_list /config/dashboards/
I’m not sure if there’s a way you can merge them into a single list if they’re in different directories.
This is all detailed in https://www.home-assistant.io/docs/configuration/splitting_configuration/
Thanks. That does seem to work with the simple example I provided above; now when I try and, for example, add my entire front office, I don’t get the icon overlays loaded… just the layout.png; it’s just blank; no error messages.
    panel: true
    cards:
        elements: !include_dir_merge_list /config/dashboards/floorplans
fo_floorplan.yaml
# FRONT OFFICE
- type: image
  style:
    left: 50%
    top: 50%
    width: 100%
    filter: >-
      ${ "hue-rotate(" +
      : 0) + "deg)"}
    opacity: >-
      / 255) : '0'}
  state_image:
  tap_action:
    action: none
- type: image
  style:
    left: 50%
    top: 50%
    width: 100%
    filter: >-
      ${ "hue-rotate(" +
      "deg)"}
    opacity: >-
      '0'}
  state_image:
  tap_action:
    action: none
- type: image
  style:
    left: 50%
    top: 50%
    width: 100%
    filter: >-
      ${ "hue-rotate(" +
      "deg)"}
    opacity: >-
      '0'}
  state_image:
  tap_action:
    action: none
fo_elements.yaml:
# FRONT OFFICE
- type: icon
  icon: mdi:desk
  style:
    left: 78.2%
    top: 75%
    opacity: 75%
    transform: scale(1.75,1.75)
    color: orange
  tap_action:
    action: fire-dom-event
    browser_mod:
      service: browser_mod.popup
        content:
          type: vertical-stack
          cards:
            - type: custom:mushroom-title-card
              title: Front Office
              alignment: justify
            - type: custom:mushroom-chips-card
              chips:
                - type: menu
                - type: entity
                  entity: sensor.main_floor_temperature
                  icon_color: orange
                - type: entity
                  entity: sensor.main_floor_humidity
                  icon_color: indigo
                - type: template
                  content: |-
                    {% set lights = ['light.front_office_overhead_lights_dimmer',
                    'light.front_office_desk_lamp', 'light.front_office_fan_light'] %}
                    {% set total = lights|select('is_state', 'on')|list|count %}
                    ({{total}}) Lights ON
                  icon: mdi:lightbulb-group
                  icon_color: |-
                    {% if total > 0 %}
                      orange
                    {% else %}
                      grey
                    {% endif %}
                - type: template
                  content: |-
                    {% if is_state('fan.front_office_fan', 'on') %}
                       Fan is ON
                    {% else %}
                       Fan is OFF
                    {% endif %}
                  icon: mdi:fan
                  icon_color: |-
                      green
                    {% else %}
                      grey
                    {% endif %}
            - type: horizontal-stack
              cards:
                - type: custom:mushroom-light-card
                  show_brightness_control: true
              cards:
                - type: custom:mushroom-fan-card
                  entity: fan.front_office_fan
                  icon_animation: true
                  show_percentage_control: true
