Dashboard disappeared after change of url
Ive for some time used homeassistant.local:8123 to access my dashboard in my browsers, but suddenly I decided to use the ip:8123 to access it instead. To my surprise, when i enter the ip:8123 my dashboard is invisible.
The dashboard still works, and you can click the buttons that used to be there, you just cant see them. If i type in my ip:8123/config i still cant see anything on screen, but i can press everything as normal.
Thanks in advance
And you have cleared your browser cache?
Yes, and ive tried both Brave and Edge, same result.
