Dashboard does not fit in tablet
I just bought a HUAWEI MediaPad T3 7. The resolution is 1024x600.
It seems like whatever I try, my dashboard is larger than my screensize. I use the skin called “dark1” - and as far as I can tell it is created to fit a 1024x600 screen.
It seems like the page is “zoomed” for some reason.
I ideally want to use the wallpanel app to display my dashboards.
Any idea on what I could try to make it work?
Oh - and my tablet browser takes AGES to load the dashboards.
I manually changed widget dimensions and margins until the dashboard fit. I am using a Fire HD 8 tablet with a screen resolution of 1280 x 800 pixels and a Wallpanel fork with support for auto brightness.
My dashboard config:
widget_dimensions: [116, 116]
widget_margins: [4, 4]
columns: 8
Adding up the pixels, the dashboard size would be 8 columns * (116 + 4 + 4) = 992 pixels wide, and 5 rows * (116 + 4 + 4) = 620 pixels high. Width and height are 77.5% of the tablet’s screen resolution, so it appears as if some zooming is happening there.
zooming can happen by the browser or app you use to show the dashboard.
the best way to avoid that is to fit your dashboard to your resolution.
  • first get your screenwidth (for example 1024)
  • then decide how many widgets you would like besides each other (for example columns: 8)
  • then decide if and how width you would like your margin. (for example 10)
  • the dimension from the widget then will be > x=((1024-10)/8)-10=116.75 so chose 117 or 116
  • then get your screenheight (for example 600)
  • then decide how many widgets you would like beneath each other (for example 6)
  • the dimension from the widget then will be > x=((600-10)/6)-10=88,3 so chose 88
now you settings will be:
widget_dimensions: [116, 88]
widget_margins: [10,10]
columns: 8
with these settings you will get no zooming, because it fits your resolution.
do you still get zooming? then you have bad settings in the app or browser and/or the wrong app or browser.
only the background can be a certain size, but a skin cant be for a screensize because you set the screensize in the dashboard with the amount of widgets and the size from the widgets.
Thank you - your posts helped me a lot. I now have a functional grid that also performs reasonable well. The original skin I used was designed with widget_dimensions [1, 1]
designing with widget_demensions[1,1] is possible.
it has some advantages but also some disadvantages.
advantages:
  1. more flexibility in placing widgets
  2. different widget sizes in 1 dashboard possible
  3. topbars and bottombars possible
  4. different margins in 1 dashboard possible
disadvantages:
  1. a lot slower loading from the dashboard
  2. an extrem amount of calculating to place widgets right needed
  3. the code isnt that easy to read
  4. changes take a lot of efford and time
so its not something for everyone. and most of all not advisable for new users. :wink:
Hallo Rene,
Waar moet deze tekst toegevoegd worden?
this forum is english only.
and i hope you realise this topic is about HADashboard from appdeamon and not HAdashboard from home assistant
if its about the appdaemon dashboards, the look at the docs.
