Dashboard editor not working correctly
Hi All,
I’ve noticed that over the past xx number of releases my dashboards have become basically uneditable from the UI. What I mean by this is that I can go in and choose the element to edit, such as a vertical stack, however it seems to pick up an item that is not even embedded in that vertical stack.
The image below shows how the dashboard renders.
If we just look at the left side column, it is made up with 2 horizontal stacks, one containing the image links, and the lower one which is divided into 3 vertical stacks contains all the lights, etc.
Looking at the second horizontal stack, you can see each of the 3 vertical stacks listed, however the first vertical stack only contains a single image which is part of the top row image links.
If I were to save at this point, the yaml for all the first column, being Front Porch down to the video stream will be replaced by the image.
However, switching to the visual editor shows the correct information as per below
Finally, going back to yaml view, it is now also correct.
This was always working however however as I don’t edit the dashboards on a regular basis I do not know at which version update the issue started.
Cheers,
Paul
You need to report this here:
Before reporting the issue make sure that it is not a just a browser cache issue.
The browser will often cache a page for faster viewing later, but this is with the risk of the page having changed since the cache was made, which will typically show itself as you describe here.
Try to clear the cache in your browser and make sure you get everything in the cache deleted related to HA.
If you are not sure you get everything then deleting it all might be a way, but beware that you might delete login information and other stored stuff for other webpages too then.
Definitely isn’t a caching issue.
