In the dashboard, the sensor value is shown with a comma “,” (the point is used to separate thousends, if the value is big enough) - this is how I expect it (Format n.nnn,dd)
The attribute value is shown with a point as comma. (Format nnnn.dd)
It is not clear to me what this has to do with currency values (it is about energy?), but I think this might be because Home Assistant is probably always using points as decimal sign in the background, independent of how it is set to be in the UI.
To be sure: did you set the Number format correctly in your HA Profile?
Anyhow, this attribute value probably is a string value representing the value calculated in the background.
Do you see any other attribute values of other entities that are using a comma as decimal sign?
What you could try is creating an extra template sensor that converts that attribute value from the string (with a point as decimal sign) into a float value (with a comma as decimal sign).
Something like this:
template:
- sensor:
- name: Energy last period
unit_of_measurement: "kWh"
state: "{{ state_attr('sensor.ed_ref_return_daily', 'last_period') | replace('.', ',') | float(0) }}"
This extra sensor can now be used in the Entities card.
