following the sheet to try and set this up and I have what might be a dumb question, but here goes.
in the examples section the first line is
“Don’t forget to add your input_text or var entity in your configuration.yaml! ;)”
I have no idea what this means (yes, I’m still new to HA)
edit: I know what configuration.yaml is and can edit it, I just don’t know where the aforemention things would go and syntax for them.
This custom card works with an input_text entity.
To use the card - you need to have an input_text entity.
You can create an input_text entity from a Helpers page.
See docs about input_text helper on the HA site.
I’m so glad you asked this question. I’m also struggling to add this multiline card to my dashboard. I do have input_text created through helper and I have the entity name but my dashboard is not recognizing this card type. any idea?
