After moving appdaemon to a virtual env and at the same time upgrading to the latest version the Dashboard is showing as before but is not functional anymore which it was before the move/upgrade.
I have Installed:
HA: 0.65.5
Python: 3.5.3
appdaemon, Version: 2.1.12
hass-apps, Version: 0.20180310.1
appdaemon.yaml:
AppDaemon:
logfile: /home/appdaemon/appdaemon/daemon.log
errorfile: /home/appdaemon/appdaemon/error.log
logsize: 100000
log_generations: 3
threads: 10
#debug: True
HASS:
ha_url: http://192.168.1.70:8123
ha_key: !secret http_password
HADashboard:
#dash_force_compile: 1
dash_url: http://192.168.1.70:5050
dash_password: !secret dash_password
daemon.log
2018-03-19 12:24:05.021908 INFO AppDaemon Version 2.1.12 starting
2018-03-19 12:24:05.022869 INFO Configuration read from: /home/appdaemon/appdaemon/conf/appdaemon.yaml
2018-03-19 12:24:05.170385 INFO Starting Apps
2018-03-19 12:24:05.495037 INFO Got initial state
2018-03-19 12:24:05.497108 INFO Loading Module: /home/appdaemon/appdaemon/conf/apps/hello.py
2018-03-19 12:24:05.499598 INFO Loading Module: /home/appdaemon/appdaemon/conf/apps/hass_apps_loader.py
2018-03-19 12:24:05.560216 INFO Loading Object verwarming using class HeatyApp from module hass_apps_loader
2018-03-19 12:24:06.037830 INFO verwarming: --- heaty v0.12.3 initialization started
2018-03-19 12:24:06.088416 INFO verwarming: --- Heaty id is: 'default'
2018-03-19 12:24:06.099693 WARNING verwarming: !!! [Badkamer] [climate.badkamer] Thermostat doesn't seem to support the operation mode Heat, supported modes are: ['heat', 'off']. Please check your config!
2018-03-19 12:24:06.105488 WARNING verwarming: !!! [Badkamer] [climate.badkamer] Thermostat doesn't seem to support the operation mode Off, supported modes are: ['heat', 'off']. Please check your config!
2018-03-19 12:24:06.128920 INFO verwarming: --> [Badkamer] [climate.badkamer] Received target temperature 16.0.
2018-03-19 12:24:06.190747 WARNING verwarming: !!! [Woonkamer] [climate.woonkamer] Attributes for thermostat contain no 'operation_list', Consider disabling operation mode support.
2018-03-19 12:24:06.207299 INFO verwarming: --> [Woonkamer] [climate.woonkamer] Received target temperature OFF.
2018-03-19 12:24:06.270100 WARNING verwarming: !!! [keuken] [climate.keuken] Attributes for thermostat contain no 'operation_list', Consider disabling operation mode support.
2018-03-19 12:24:06.286567 INFO verwarming: --> [keuken] [climate.keuken] Received target temperature OFF.
2018-03-19 12:24:06.358639 WARNING verwarming: !!! [Speelkamer] [climate.speelkamer] Attributes for thermostat contain no 'operation_list', Consider disabling operation mode support.
2018-03-19 12:24:06.375128 INFO verwarming: --> [Speelkamer] [climate.speelkamer] Received target temperature OFF.
2018-03-19 12:24:06.510789 INFO verwarming: <-- [Woonkamer] Temperature set to 19.5. <scheduled>
2018-03-19 12:24:06.553012 INFO verwarming: <-- [keuken] Temperature set to 19.5. <scheduled>
2018-03-19 12:24:06.593705 INFO verwarming: <-- [Speelkamer] Temperature set to 19.5. <scheduled>
2018-03-19 12:24:06.605597 INFO verwarming: --- Initialization done
2018-03-19 12:24:06.606167 INFO App initialization complete
2018-03-19 12:24:06.606984 INFO Starting dashboard
2018-03-19 12:24:06.618430 INFO API is disabled
2018-03-19 12:24:06.630286 INFO Connected to Home Assistant 0.65.5
2018-03-19 12:24:07.090021 WARNING Logged an error to /home/appdaemon/appdaemon/error.log
2018-03-19 12:24:24.449685 INFO Compiling dashboard 'landscape'
2018-03-19 12:24:26.259467 INFO function [get_dashboard] finished in 1820 ms
2018-03-19 12:24:26.839842 INFO New dashboard connected: Hoog Gagel 66
2018-03-19 12:24:46.504766 INFO Dashboard disconnected
2018-03-19 12:24:47.619617 INFO function [get_dashboard] finished in 112 ms
2018-03-19 12:24:47.620442 INFO New dashboard connected: Hoog Gagel 66
2018-03-19 12:24:47.656625 INFO Dashboard disconnected
2018-03-19 12:24:48.268313 INFO New dashboard connected: Hoog Gagel 66
2018-03-19 12:24:53.987174 INFO Dashboard disconnected
2018-03-19 12:31:17.010639 WARNING Logged an error to /home/appdaemon/appdaemon/error.log
2018-03-19 12:41:32.009982 WARNING Logged an error to /home/appdaemon/appdaemon/error.log
error.log
2018-03-19 12:24:07.089386 WARNING ------------------------------------------------------------
2018-03-19 12:31:17.007725 WARNING ------------------------------------------------------------
2018-03-19 12:31:17.008399 WARNING Unexpected error during process_message()
2018-03-19 12:31:17.008785 WARNING ------------------------------------------------------------
2018-03-19 12:31:17.009881 WARNING Traceback (most recent call last):
File "/srv/appdaemon/lib/python3.5/site-packages/appdaemon/appdaemon.py", line 771, in process_message
appdash.ws_update(data)
File "/srv/appdaemon/lib/python3.5/site-packages/appdaemon/rundash.py", line 261, in ws_update
data = json.dumps(jdata)
File "/usr/lib/python3.5/json/__init__.py", line 230, in dumps
return _default_encoder.encode(obj)
File "/usr/lib/python3.5/json/encoder.py", line 198, in encode
chunks = self.iterencode(o, _one_shot=True)
File "/usr/lib/python3.5/json/encoder.py", line 256, in iterencode
return _iterencode(o, 0)
File "/usr/lib/python3.5/json/encoder.py", line 179, in default
raise TypeError(repr(o) + " is not JSON serializable")
TypeError: OFF is not JSON serializable
2018-03-19 12:31:17.010287 WARNING ------------------------------------------------------------
2018-03-19 12:41:32.004285 WARNING ------------------------------------------------------------
2018-03-19 12:41:32.005455 WARNING Unexpected error during process_message()
2018-03-19 12:41:32.006259 WARNING ------------------------------------------------------------
2018-03-19 12:41:32.008363 WARNING Traceback (most recent call last):
2018-03-19 12:41:32.009238 WARNING ------------------------------------------------------------
There is clearly an error, however I have no clue if this is related to the dashboard not working. There is a warning in the Heaty (part of hass-apps) but it is functional (my heating is following my schedule). So what is causing the Dashboard not to work? How can I find out where the error is coming form? By the way I am running this on a RPI3 in Raspbian Stretch Lite (so no dockers). Thanks in advance for pointers on how to solve this.
