Dashboard - simple HVAC filter clean reminder
This project uses standard HA elements (Helpers, Automations, Lovelace Cards) to track HVAC running time and trigger a filter clean reminder card indication & notification. [Purpose was to keep it simple & avoid using addons or custom integrations to minimise being exposed to breaking changes].
Setup [Working with HA Core 2025.1.2]
  • An existing sensor of HVAC status running or not (i.e. on/off) used to control the runtime timer helper. [e.g. a Threshhold Helper “Trigger Aircon Running” controlled by a minimum AirCon power trigger point, or see optional config.yaml code below to create a sensor from the Daikin HA integration].
  • A Timer Helper used in a Tile card to track HVAC runtime e.g. “Daikin Filter Remaining”. [Timer Duration is setup as per desired AirCon running time filter clean interval (e.g. 90 hours), select ‘restore state’ so that timer survives HA restarts. Note that Timer Helpers only count time down i.e. time remaining].
  • An Input Boolean Helper used in a Tile card to indicate when filter clean is due e.g. “Daikin Filter Due”
  • An Input Button Helper used in a Button card to Reset the timer e.g. “Daikin Filter Reset”
Automation:
This controls the timer & cards and includes a notification when filter is due. [There is also an option to manually adjust the Timer remaining Duration, see notes in Automation].
description: >-
  Aircon Filter timer using AC runtime.
  *Option 5 disabled Action: use to manually decrease/ increase the timer by a
  desired unit of time. Check timer entities are correct, enable Action, edit
  Duration [e.g. edit Duration to -30:00:00 to decrease current timer by 30
  hours] & manually Run Action.
triggers:
  - trigger: state
    entity_id:
      - input_button.daikin_filter_reset
  - trigger: state
    entity_id:
      - binary_sensor.trigger_aircon_running
    to: "on"
    enabled: true
  - trigger: state
    entity_id:
    to: "off"
    for:
      hours: 0
      minutes: 0
      seconds: 0
    enabled: true
  - trigger: state
    entity_id:
      - timer.daikin_runtime
    to: idle
    for:
      hours: 0
      minutes: 0
      seconds: 10
conditions: []
actions:
  - choose:
      - conditions:
          - condition: trigger
            id:
              - Timer Start
        sequence:
          - action: timer.start
            metadata: {}
            data: {}
              entity_id: timer.daikin_runtime
          - action: input_boolean.turn_off
            metadata: {}
            data: {}
              entity_id: input_boolean.daikin_filter_due
      - conditions:
            id:
              - Timer Pause
        sequence:
          - action: timer.pause
            metadata: {}
            data: {}
      - conditions:
            id:
              - Timer Finished
        sequence:
          - action: input_boolean.turn_on
            metadata: {}
            data: {}
            enabled: true
          - action: notify.mobile_app_iphone_se
              message: The Daikin AC Filter is due to be cleaned
            enabled: true
      - conditions:
            id:
              - Timer Reset
        sequence:
            metadata: {}
            data: {}
          - action: timer.cancel
            metadata: {}
            data: {}
          - if:
              - condition: state
                state: "on"
                entity_id: binary_sensor.trigger_aircon_running
            then:
                metadata: {}
                data: {}
            else:
                metadata: {}
                data: {}
                metadata: {}
                data: {}
      - conditions: []
        sequence:
          - alias: >-
              Manually adjust timer duration. [Enable, set Duration delta in
              Timer ‘Change’ Action & Run this]
            sequence:
                metadata: {}
                data: {}
              - action: timer.change
                metadata: {}
                  duration: "-30:00:00"
                enabled: true
              - if:
                  - condition: state
                    state: "on"
                then:
                    metadata: {}
                    data: {}
                else:
                    metadata: {}
                    data: {}
                    metadata: {}
                    data: {}
            enabled: true
mode: single
Dashboard Cards:
yaml code for Dashboard cards
[Note - Display of Timer real-time Duration countdown only works in Entities & Tile type cards, other cards will only refresh/ display the current Timer Duration when Timer is paused].
  - cards:
      - type: tile
        show_entity_picture: false
        vertical: true
        hide_state: false
        entity: input_boolean.daikin_filter_due
        state_content: state
        tap_action:
          action: none
        icon_tap_action:
          action: none
        hold_action:
          action: none
        icon: mdi:air-filter
        color: red
    type: horizontal-stack
  - cards:
      - show_name: true
        show_icon: true
        entity: input_button.daikin_filter_reset
        hold_action:
          action: toggle
        tap_action:
          action: none
        type: button
        icon_height: 40px
        show_state: true
      - type: tile
        entity: timer.daikin_runtime
        vertical: false
        hide_state: false
        state_content: remaining_time
        name: Hrs to go
        color: amber
type: vertical-stack
type or paste code here
Optional config.yaml code below to create a HVAC status sensor from the Daikin HA integration.
    sensors:
      daikinap63347_hvac_status:
        value_template: >
          {% if state_attr('climate.daikinap63347', 'hvac_action') == 'off' %}
            Off
          {% else %}
           On
          {% endif %}
        friendly_name: 'DaikinAP63347 HVAC Status'
        unique_id: daikin-hvac-status
Cool, but to be fair, for most of these types of thing, a simple recurrent calendar item on any calendaring app is probably better and more reliable.
Thats always an option, but dirty HVAC filters are majority correlated with the unit runtime, not just over time…
Oh, what an excellent point that i had not contemplated.
