Dashboard - simple HVAC sleep timer
This project uses standard HA elements (Helpers, Automations, Lovelace Cards) to set up a simple HVAC delayed stop timer for either of two fixed time durations, with the stop timer easily able to be cancelled. [Purpose was to keep it simple & avoid using addons or custom integrations to minimise being exposed to breaking changes].
Setup [Working with HA Core 2025.1.2]
  • A Timer Helper used in a Tile card to count down time remaining e.g. “Daikin Sleep Timer”. [Timer Duration is setup as 0 as the timer duration is input using two selectable input boolean toggle helpers, select ‘restore state’ so that timer survives HA restarts. Note that Timer Helpers only count time down i.e. time remaining].
  • Two separate Toggle helpers (i.e. Input Boolean Helpers) used in separate Tile cards to select the desired fixed time to HVAC turning off e.g. “Daikin Sleep - 2 Hrs” and “Daikin Sleep - 4 Hrs”. [these helpers are used input the associated fixed duration to the timer, the preset fixed durations are able to be edited in the automation to your preference]
Automation:
This activates the sleep timer based on which of the two toggle helpers/ input booleans are selected On (2 Hrs or 4Hrs) and turns the HVAC Off once the timer has run down to zero. The automation cancels the timer if the active helper is toggled Off, if the alternate helper is toggled On, or if the HVAC itself is turned off some other way.
alias: Automation Daikin - Sleep timer
description: >-
  Turn off AC when the chosen sleep timer finishes, cancel the active sleep
  timer if the A/C is turned off some other way
triggers:
  - entity_id:
      - binary_sensor.daikinap63347_hvac_status
    to: "off"
    trigger: state
  - entity_id:
    to: "on"
    trigger: state
  - trigger: state
    entity_id:
      - input_boolean.daikin_sleep_2_hrs
    to: "on"
  - trigger: state
    entity_id:
    to: "off"
  - trigger: state
    entity_id:
      - input_boolean.daikin_sleep_4_hrs
    to: "on"
  - trigger: state
    entity_id:
    to: "off"
  - trigger: state
    entity_id:
      - timer.daikin_sleep_timer
    for:
      hours: 0
      minutes: 0
      seconds: 0
    to: idle
conditions: []
actions:
  - choose:
      - conditions:
          - condition: trigger
            id:
              - AirCon On
        sequence:
          - action: input_boolean.turn_off
            metadata: {}
            data: {}
              entity_id: input_boolean.daikin_sleep_2_hrs
            metadata: {}
            data: {}
              entity_id: input_boolean.daikin_sleep_4_hrs
      - conditions:
            id:
              - AirCon Off
          - condition: state
            state: active
            entity_id: timer.daikin_sleep_timer
        sequence:
          - action: timer.finish
            metadata: {}
            data: {}
      - conditions:
            id:
              - Timer End
        sequence:
          - data: {}
            action: climate.turn_off
              entity_id: climate.daikinap63347
            metadata: {}
            data: {}
            metadata: {}
            data: {}
      - conditions:
            id:
              - Timer 2hrs
        sequence:
            metadata: {}
            data: {}
          - action: timer.start
            metadata: {}
              duration: "02:00:00"
      - conditions:
            id:
              - Timer 4hrs
        sequence:
            metadata: {}
            data: {}
            metadata: {}
              duration: "04:00:00"
      - conditions:
            id:
              - Timer 2off
        sequence:
          - action: timer.cancel
            metadata: {}
            data: {}
            metadata: {}
            data: {}
      - conditions:
            id:
              - Timer 4off
        sequence:
            metadata: {}
            data: {}
            metadata: {}
            data: {}
mode: single
Dashboard Cards:
yaml code for Dashboard cards, the Timer tile card is set to touch action None.
AirCon Sleep timer
[Note - Display of Timer real-time Duration countdown only works in Entities & Tile type cards, other cards will only refresh/ display the current Timer Duration when Timer is paused].
type: vertical-stack
cards:
  - type: heading
    heading_style: subtitle
    heading: AirCon Off delay
  - type: horizontal-stack
    cards:
        cards:
          - type: tile
            vertical: true
            icon: mdi:clock-end
            color: green
            tap_action:
              action: toggle
            icon_tap_action:
              action: toggle
            hold_action:
              action: none
            entity: input_boolean.daikin_sleep_2_hrs
          - type: tile
            vertical: true
            icon: mdi:clock-end
            color: green
            tap_action:
              action: toggle
            icon_tap_action:
              action: toggle
            hold_action:
              action: none
            entity: input_boolean.daikin_sleep_4_hrs
          - type: tile
            icon: mdi:timelapse
            color: amber
            vertical: true
            state_content: remaining_time
            icon_tap_action:
              action: none
            hold_action:
              action: none
            name: Time 2 Sleep
            tap_action:
              action: none
            entity: timer.daikin_sleep_timer
