Thanks for the help. The second part worked correctly but the first didn’t, it just shows me the same thing. Any ideas? I use the latest version of the card.
And now, abusing his wisdom. How can I change the font in the red boxes? And how can I change the background color to black in the text of the second image? Thanks in advance. All the best.
You need the beta as I said
The update just skipped me. I’ll look at it tomorrow without fail. Thank you so much. Can something be done about the other two questions?
Not supported by default, but you can hack the css with GitHub - thomasloven/lovelace-card-mod: 🔹 Add CSS styles to (almost) any lovelace card
type: custom:sonos-card
card_mod:
style:
sonos-grouping$: |
sonos-grouping-button {
--accent-color: black;
font-size: 30px;
v7.0.0 released
Breaking changes
- Favorites are now shown as icons instead of list by default, can be changed to list with
mediaBrowserItemsPerRow: 1. - Favorite titles are now shown by default. Can be hidden with
mediaBrowserHideTitleForThumbnailIcons: true. - Urls for thumbnails are no longer rewritten from http to https. Can be enforced with
replaceHttpWithHttpsForThumbnails: true.
Highlights
- feature: make it possible to show non-sonos players
- feature: show volume in grouping
- feature: allow non-sonos players in the visual editor
- feature: configurable volume step size
- feature: make it possible to adjust volume relative to main player
And much more! See full release log here. Documentation in initial post has been updated.
maybe im blind, but how and where did you add these icons to the card?
ive had that for a long time, but how do i use them is the sonos card ?
ok i see it says if youve configured the entity. i did but let me do a them refresh
Continuing with the queries and very grateful for it.
Photo 1: As you can see, my image does not exceed the size of the antennas in the TV image. Can I make said image disappear or enlarge mine a little?
Photo 2: Could we change the default icons for ones with a better design or custom ones? Thank you for such a wonderful card. It’s my favorite.
Hi! Thank you, a lot, for your efforts and this great card!
One question: I managed to remove the border radius from the media browser icons. But how can I remove the rounded corners of the gray “shadow” or additional “boarder” around (or totally remove it)?
This is my present code:
theme: sonos
sections:
- media browser
topFavorites:
dynamicVolumeSlider: false
mediaBrowserItemsPerRow: 4
mediaBrowserShowTitleForThumbnailIcons: true
showVolumeUpAndDownButtons: false
heightPercentage: 123
mediaArtworkOverrides: []
entityNameRegexToReplace: Sonos Küche
widthPercentage: 113
entityId: media_player.sonos_kueche
mediaBrowserTitle: Meine Favoriten
card_mod:
style:
sonos-media-browser$ sonos-media-browser-icons$: |
div {
border: none;
border-radius: 0px !important;
color: white !important;
font-size: 18px !important;
font-weight: 300 !important;
1: use fallbackArtwork: <url to your own image>
2: I’m afraid not, that is not supported
card_mod:
style:
sonos-media-browser$: |
sonos-media-browser-icons {
--rgb-card-background-color: transparent;
Thank you!
Like this?
It has no effect at the moment…
theme: sonos
sections:
- media browser
topFavorites:
card_mod:
style:
div {
border: none;
Now it’s getting complex.
I see that those two collide though. since sonos-media-browser$ is there two times.
Not sure what the solution is.
I recommend you to dig into the card-mod documentation for that.
I used the “explore and download repositories button”. Search fro Sonos, but this repo does not show up. What do i miss?
Looks like you are searching integrations. Sonos-card is under frontend.
Thanks. Feeling like a NOOB. I missed that completely.
Hm, I noticed the following: Even when using this as single modification with card_mod it doen’t work as desired. It removes the background behind the text but does not remove the rounded corners of the frame arount the icons. I’m not sure it has the effect wanted, since changing transparent to e.g. black has no result (background behind text remains transparent).
card_mod:
style:
div {
border: none;
color: black !important;
ha-card {
--sonos-border-radius: 0px !important;
--primary-color: none;
--secondary-background-color: none;
--sonos-ha-card-background-color: none;
--ha-card-box-shadow: none;
card_mod:
style:
