I try to use 2 rows for 100% wide … but dont know how, can someone give me a hint ?
you can install Layout card then edit your dashboard page and change the size of each column.
with something like this
width: 500
max_cols: 2
Thanks for answer…will try this
I try since 2 hours, the “wide” has no effect, I try also width: 500 , width: 800 , width: 1500 … left + right Space as before
not for :
masonry(Layout card)
horizontal(Layout card)
vertical(Layout card)
grid (Layout card)
yaml :
title: test
path: test
type: custom:masonry-layout
width: 500
max_cols: 2
cards:
- type: entities
entities:
- entity: binary_sensor._battery_charge
title: Test0
- square: false
type: grid
columns: 1
cards:
- show_state: true
show_name: true
- type: entities
entities:
- entity: sensor.batterie
- entity: button
secondary_info: last-changed
title: test1
anyone can help ?
you need to indent width and max cols like this
layout_type: custom:masonry-layout
layout:
width: 400
max_cols: 2
that’s if you have layout card installed
