Dashboard would not connect to Raspberry pi server
Hi everyone,
Currently I can not get my dashboard connect to raspberry pi server. It worked almond 2 years without any major issues up until this happened. Yesterday, I accidentally turned the power off to the rpi and started this issue after I turned the power back on. All my automations are work flawlessly and I am able connect to the rpi from my phone (iOS) and windows computer. I am using Amazon fire 10” as my dashboard. Please see the attached picture regarding current issue
Thank you so much for any input
First, basic, set of questions:
  • Does your pi have a static IP address?
  • Is it possible that it is no longer 192.168.1.101?
  • From the other devices, do you connect through
    a. a name like “homeassistant:8123” or
    b. in auto-discover or
    c. via the IP address?
If you can connect in ssh from “whatever device”, can you do a
netstat -an | grep 8123
That should look like
tcp 0 0 0.0.0.0:8123 0.0.0.0:* LISTEN
EDIT: basic* as I assume that you probably already tried to assess those questions
Thank you for your quick reply.
Yes I did try with “homeassistant:8123” also with ip address. I don’t have static ip on pi.
Could be a very good idea to fix the address in your router somehow, Google is your friend to find the way to do so.
Anyway, if you manage to connect in ssh, can you also do a
ip addr
That will give you the current address of your pi, like this
inet 192.168.1.101/24 brd 192.168.1.255 scope global dynamic noprefixroute wlan0
or, if you can’t connect in ssh, check your router for the list of connected devices and try to find your home assistant pi.
I am not familiar with how to do ssh connect. If you would please provide me more details. I am using Linksys router and can’t locate my server ip. I’ve connected rp directly in to the router and no luck
Did you have a look in the manual for you specific model (Linksys Official Support - User Guides, Downloads, FAQs)?
You should be able to find the dhcp leases there.
Thank you guys for helps and tips, everything works properly now
