2018-03-16 14:50:09.745893 INFO AppDaemon Version 3.0.0b5 starting
2018-03-16 14:50:09.747390 INFO Configuration read from: /home/homeassistant/.homeassistant/.appdaemon/conf/appdaemon.yaml
2018-03-16 14:50:09.749731 INFO AppDaemon: Starting Apps
2018-03-16 14:50:09.755904 INFO AppDaemon: Loading Plugin HASS using class HassPlugin from module hassplugin
2018-03-16 14:50:09.994060 INFO AppDaemon: HASS: HASS Plugin Initializing
2018-03-16 14:50:09.995363 INFO AppDaemon: HASS: HASS Plugin initialization complete
2018-03-16 14:50:09.996234 INFO Starting Dashboards
2018-03-16 14:50:10.012147 INFO API is disabled
2018-03-16 14:50:10.016274 WARNING AppDaemon: HASS: Disconnected from Home Assistant, retrying in 5 seconds
2018-03-16 14:50:15.021919 WARNING AppDaemon: HASS: Disconnected from Home Assistant, retrying in 5 seconds
2018-03-16 14:50:20.027556 WARNING AppDaemon: HASS: Disconnected from Home Assistant, retrying in 5 seconds
2018-03-16 14:50:25.031871 WARNING AppDaemon: HASS: Disconnected from Home Assistant, retrying in 5 seconds
2018-03-16 14:50:36.889636 WARNING AppDaemon: HASS: Disconnected from Home Assistant, retrying in 5 seconds
2018-03-16 14:50:41.895097 WARNING AppDaemon: HASS: Disconnected from Home Assistant, retrying in 5 seconds
2018-03-16 14:50:46.900757 WARNING AppDaemon: HASS: Disconnected from Home Assistant, retrying in 5 seconds
2018-03-16 14:50:52.523531 INFO AppDaemon: HASS: Connected to Home Assistant 0.65.5
2018-03-16 14:50:53.370161 INFO AppDaemon: Adding /home/homeassistant/.homeassistant/.appdaemon/apps to module import path
2018-03-16 14:50:53.371015 INFO AppDaemon: Processing restart for HASS
2018-03-16 14:50:54.719539 INFO AppDaemon: App initialization complete
access logs:
2018-03-16 14:23:37.925459 INFO Compiling dashboard 'FirePanel'
2018-03-16 14:23:38.450140 WARNING Dashboard 'FirePanel' not found
2018-03-16 14:23:38.451005 WARNING ------------------------------------------------------------
2018-03-16 14:23:38.451428 WARNING Unexpected error during DASH creation
2018-03-16 14:23:38.451844 WARNING ------------------------------------------------------------
2018-03-16 14:23:38.453765 WARNING Traceback (most recent call last):
File "/srv/homeassistant/lib/python3.5/site-packages/appdaemon/dashboard.py", line 822, in get_dashboard
with open(include_path, "r") as include_file:
FileNotFoundError: [Errno 2] No such file or directory: '/home/homeassistant/.homeassistant/.appdaemon/conf/compiled/html/default/firepanel_head.html'
2018-03-16 14:23:38.454280 WARNING ------------------------------------------------------------
2018-03-16 14:23:38.454664 INFO function [get_dashboard] finished in 547 ms
After the upgrade to v3 I was having some trouble and while troubleshooting I deleted my compiled dir, but now AD does not compile the dashboards looks like.
you deleted the dirs, and they are back there, but do they have the right rights?
appdaemon should have full control in the dirs. (and the complete conf dir)
this dir structure “.homeassistant/.appdaemon” is what unusaual, but shouldnt give problems if setup correctly.
Thanks for your reply. Yes, I deleted the content of the compiled dir and at restart of app the system created css and javascript directories but I had to manually create html dir to try resolve the error above. Also, the owner is the homeassistant user, same one I use to run AD.
Regarding the file structure, appdaemon used to work properly prior the upgrade to v3, so I thought it would not be the problem.
to make sure that nothing is hanging somewhere do these steps in this order:
||close all dashboards|
||clear the cash from the browsers that you use the dashboards in|
||close appdaemon|
||clear your logfiles|
||clear the subdirectories that are in conf/compiled but leave the structure|
||close the device that is running appdaemon|
||restart the device that is running appdaemon|
||restart appdaemon|
||open 1 dashboard in google chrome|
||if you still have problems then look at the java console (CTRL Shift I) in chrome for errors and look in your logfiles for errors. |
|o|which python version you are running|
|o|the logfiles from the start|
|o|the java console error(s)|
I already saw this suggestion in another post and I already tried it few times. The AP page does not load at all, it just returns a white page when I go to http://IP_ADDRESS:5050 and I’m afraid that b/c I have no content at all in the compiled directory.
houtknots, I don’t use hassio, but I believe that my issue is related to the config that never gets created/compiled.
i would try to lose the dot before appdaemon
by the way, which version from python do you use?
and is the homeassistant user owner from the compiled dir and does it have wtiting access in the complete structure?
and i noticed that the css, html and js directories are in the conf dir, they need to be in the compiled dir.
I can try to remove the . from the appdaemon directory.
However the file structure as the confing, did not come out with the right spacing, so it does not reflect the proper structures. See below for the response to your questions:
$ ls -la .appdaemon/
total 24
drwxr-xr-x 6 homeassistant casa 4096 Mar 16 14:20 .
drwxr-xr-x 12 homeassistant casa 4096 Mar 17 12:20 …
drwxr-xr-x 2 homeassistant casa 4096 Mar 16 14:20 apps
drwxr-xr-x 3 homeassistant casa 4096 Mar 16 20:00 conf
drwxr-xr-x 2 homeassistant casa 4096 Mar 16 19:58 dashboards
drwxr-xr-x 2 homeassistant casa 4096 Mar 16 14:22 logs
$ ls -la .appdaemon/conf/
total 20
drwxr-xr-x 3 homeassistant casa 4096 Mar 16 20:00 .
drwxr-xr-x 6 homeassistant casa 4096 Mar 16 14:20 …
-rwxr-xr-x 1 homeassistant casa 919 Mar 16 19:56 appdaemon.yaml
drwxr-xr-x 5 homeassistant casa 4096 Mar 16 14:35 compiled
-rw-r–r-- 1 homeassistant casa 25 Mar 16 14:22 secrets.yaml
$ ls -la .appdaemon/conf/compiled/
total 20
drwxr-xr-x 5 homeassistant casa 4096 Mar 16 14:35 .
drwxr-xr-x 3 homeassistant casa 4096 Mar 16 20:00 …
drwxr-xr-x 2 homeassistant casa 4096 Mar 16 14:22 css
drwxr-xr-x 2 homeassistant casa 4096 Mar 16 14:35 html
drwxr-xr-x 2 homeassistant casa 4096 Mar 16 14:22 javascript
$ python --version
Python 3.5.3
2018-03-17 12:30:46.201470 INFO Compiling dashboard ‘FirePanel’
2018-03-17 12:30:46.767727 WARNING Dashboard ‘FirePanel’ not found
2018-03-17 12:30:46.768678 WARNING ------------------------------------------------------------
2018-03-17 12:30:46.774620 WARNING Unexpected error during DASH creation
2018-03-17 12:30:46.775117 WARNING ------------------------------------------------------------
2018-03-17 12:30:46.779521 WARNING Traceback (most recent call last):
File “/srv/homeassistant/lib/python3.5/site-packages/appdaemon/dashboard.py”, line 822, in get_dashboard
with open(include_path, “r”) as include_file:
FileNotFoundError: [Errno 2] No such file or directory: ‘/home/homeassistant/.homeassistant/appdaemon/conf/compiled/html/default/firepanel_head.html’
2018-03-17 12:30:46.780111 WARNING ------------------------------------------------------------
2018-03-17 12:30:46.780509 INFO function [get_dashboard] finished in 617 ms
and the html dir is still empty…
$ ls -la /home/homeassistant/.homeassistant/appdaemon/conf/compiled/html/
total 8
drwxr-xr-x 2 homeassistant casa 4096 Mar 16 14:35 .
drwxr-xr-x 5 homeassistant casa 4096 Mar 16 14:35 …
$ ls -la appdaemon/dashboards/
total 24
drwxr-xr-x 2 homeassistant casa 4096 Mar 16 19:58 .
-rwxr-xr-x 1 homeassistant casa 7673 Mar 16 19:58 FirePanel.dash
-rwxr-xr-x 1 homeassistant casa 200 Mar 16 19:58 hello.dash.disabled
-rwxr-xr-x 1 homeassistant casa 1029 Mar 16 19:58 IPCameras.dash
[/details]
Sorry for the formatting, I fixed it now.
Also I get nothing when I go to http://10.1.190.49:5050, white empty page, that’s it. With 2.12 I used to get the AppDaemon home page with the links to my dashboards.
then your dashboard server isnt running correct.
the whitscreen in google chrome also probably has an error.
so go to the java console to see that error. (ctrl shift I)
and after you have changed things like directories and have problems, its wise to do the whole list again:
||close appdaemon
||clear your logfiles
||restart appdaemon
|o|show the logfiles from the start
|o|show the java console error(s)
