Can anyone share an example of how to configure multiple dashboards through yaml? I’ve read through the v0.107 release notes and looked at the info page. I’m clearly missing something…?
Should the dashboard name be the same as the filename? Can it be?
Is there any way to move all of the dashboard files into a separate directory? When I tried filename: "/config/ui/hidden.yaml" the Filename listed in the dashboard section was configuihidden.yaml.
