I was looking for a way to cast a HADashboard to my Chromecast, without having to cast a tab from a browser.
Luckily, pychromecast has support for DashCast. Unfortunately there seems to be no built-in way to use it from within HA, so I decided to write an AppDaemon app for it:
At the moment, it takes a URL and the IP address of the Cast device.
The stuff I need help with:
I’m running the AppDaemon add-on in hass.io, and it seems like it doesn’t have support for mdns/bonjour/autodisccovery, so unfortunately I can’t select the Cast device by friendly name like I wanted to (see commented out code).
I’ve spent some time trying to add the mdns packages, but I didn’t have any luck. Any help would be appreciated.
the idea is nice, but i am afraid it wont work with hassio.
when i understood correctly, things that you want to discover from outside a docker or be visible on the network, need to be declared in the docker setup. (the addon creator needs to do that)
so unless you find a way to expose it through the dashboard, or the appdaemon api, i think you did run into hassio restrictions.
stuff like this is more advanced use from your server(s), hassio is more for people who dont want to tinker in a linux/python environment.
by the way, it could be that my answer is wrong, because i am confused with your question.
after reading the fourth time i am sure i have it wrong, but still dont know what it is you want, what doesnt work.
I think you’re partly right. What isn’t working, is the autodiscovery (by receiving the UDP broadcasts from the cast devices). It works just fine as long as I specify the IP address of the cast device, so it can connect directly.
if i understand that correctly, you are not able to listen to the network, but you can make a connection directly.
so only a minor disfunction.
for me that is fully functional. because i dont want autodiscover functions anyway (i rather give in settings myself then that my home automation changes settings)
ill take a closer look at it myself later on. to look if i can use this to send dashboards to my tv by using an automation.
I have tested Dashcast months ago and it worked. HASS GUI was sent to my TV. I didn’t have much time and didn’t look much into it but it seemed it didn’t work reliably. After some time if I used Chromecast for something else it wouldn’t be sent.
FYI I was using some ready made docker container.
I can share my configuration later if you wish.
Sure, I’d love to see different solutions to this issue. I’m also wondering if making it into a component could somehow make it easier to do autodiscovery, possibly leveraging the already-discovered cast devices.
I dunno much about AppDaemon or containers, or if this relevant to hassio.
Could someone please confirm if this can run on hassio and give me a step-by-step?
Hello @DarkFox ,
how can I run your appdeamon dashcast app? I am using AppDeamon3 addon, I copied your dashcast.py , adde pychromecast package and altered apps.yaml Should I hardcode receiver and url into dashcast.py? Last log lines:
2018-11-24 17:35:20.392577 INFO dashcast: Init Dashcast
2018-11-24 17:35:20.392932 INFO AppDaemon: App initialization complete
What should I do next? Sorry but this is my first experiance with appdeamon.
