because of some reason I need to install clean system and copied some config files etc.
Now I need to have my buttons up and running again.
I just use the simple son file I used around 1,5 years now.
But, with the new authentication system in place I am not sure how to log in successfully any more.
Dasher itself is seeing the pressed button but I get the message
[2018-09-24T16:36:53.243Z] Afri Cola -> Dash Button 10 pressed. Count: 1
[2018-09-24T16:36:53.551Z] Not authenticated
[2018-09-24T16:36:53.552Z] Unsuccessful status code
Here is the json code I use:
"name": "GBC -> Dash Button 2 ",
"address": "50:f5:da:8b:d1:c4",
"url": "http://192.168.1.66:8123/api/services/light/toggle",
"interface": "eth0",
"method": "POST",
"headers": {"mainusername": "mainuserpassword"},
"json": true,
"protocol": "udp",
"body": {"entity_id": "light.buro"}
I am not quite sure about the api right now, maybe someone can help me out here.
Also i am seeing failed login attempts from its own ip in the dashboard, as they appear right after I pressed the button I guess its dasher and because something in the code is wring the error message is happening.
Thanks in advance.
