Dasher press happening twice
So whenever I press my dash button to toggle some lights it appears that the press is registering twice. I do have the auto start script from Bruh Automation running. Not sure if that’s the issue. Here is my dasher config:
"name": "Toggle Lights",
"address": "xx:xx:xx:xx:xx:xx",
"url": "http://xxx.xxx.x.xx:8123/api/services/light/toggle",
"method": "POST",
"headers": {"x-ha-access": "xxxxxx"},
"json": true,
"body": {"entity_id": "group.all_lights"}
This is the init script for autostarting Dasher. I don’t understand it well enough to know if there is a problem here.
#!/bin/sh
### BEGIN INIT INFO
# Provides: homebridge
# Required-Start:    $network $remote_fs $syslog
# Required-Stop:     $remote_fs $syslog
# Default-Start:     2 3 4 5
# Default-Stop:      0 1 6
# Short-Description: Start daemon at boot time
# Description:       Enable service provided by daemon.
### END INIT INFO
dir="/home/pi/dasher"
cmd="DEBUG=* node app.js"
user="root"
name=`basename $0`
pid_file="/var/run/$name.pid"
stdout_log="/var/log/$name.log"
stderr_log="/var/log/$name.err"
get_pid() {
    cat "$pid_file"
is_running() {
    [ -f "$pid_file" ] && ps `get_pid` > /dev/null 2>&1
case "$1" in
    start)
    if is_running; then
        echo "Already started"
    else
        echo "Starting $name"
        cd "$dir"
        if [ -z "$user" ]; then
            sudo $cmd >> "$stdout_log" 2>> "$stderr_log" &
        else
            sudo -u "$user" $cmd >> "$stdout_log" 2>> "$stderr_log" &
        fi
        echo $! > "$pid_file"
        if ! is_running; then
            echo "Unable to start, see $stdout_log and $stderr_log"
            exit 1
        fi
    fi
    stop)
    if is_running; then
        echo -n "Stopping $name.."
        kill `get_pid`
        for i in {1..10}
        do
                break
            fi
            echo -n "."
            sleep 1
        done
        echo
        if is_running; then
            echo "Not stopped; may still be shutting down or shutdown may have failed"
            exit 1
        else
            echo "Stopped"
            if [ -f "$pid_file" ]; then
                rm "$pid_file"
            fi
        fi
    else
        echo "Not running"
    fi
    restart)
    $0 stop
    if is_running; then
        echo "Unable to stop, will not attempt to start"
        exit 1
    fi
    $0 start
    status)
    if is_running; then
        echo "Running"
    else
        echo "Stopped"
        exit 1
    fi
    echo "Usage: $0 {start|stop|restart|status}"
    exit 1
esac
exit 0
I have a fix for now. I set the timeout to 60,000. So you have to wait a minute to press again but it doesn’t happen twice at the very least.
"timeout": "60000",
Did this fix it permanently for you? I changed mine to even longer and it still happens maybe 30% of the time
Never mind I had two instances running
Yeah check for two instances, but this so far has worked for me
