Seriously.
Is Dasshio working for anyone else since hassio supervisor 121?
Seriously.
No it isnât.
If you read other threads here youâd see itâs a blanket balls up affecting things that use @home_assistant and nothing so far has fixed it.
Get the following errors in the Hassio Supervisor System Log. Not seeing anything recent in the forum with this message. Could just be affecting Dasshio.
18-07-25 19:25:38 WARNING (MainThread) [hassio.api.proxy] Unknown HomeAssistant API access!
18-07-25 19:52:29 WARNING (MainThread) [hassio.api.proxy] Unknown HomeAssistant API access!
18-07-25 19:55:04 WARNING (MainThread) [hassio.api.proxy] Unknown HomeAssistant API access!
See post above yours
I saw that but no one else seems to have posted the same error message which I find strange if this is affecting others.
Iâm down again after 121 update.
Will roll out a new version during today. Thanks!
Is there any update on this?
we need to be patient I expect Home Assistant to have more breaking changes as we get to new level of security (2fa and others) as for the effort of danimb all I can say is than you for taking your time to help the community I can patiently wait till this issue is resolved since I do not have the skills to fix it myself.
Iâm not being impatient, just responding to the suggestion that it would be fixed yesterday.
It was just a simple question.
There is a workaround from e2m32 that will get you up and running again until this current issue is fixed
âtimeoutâ: 20,
âbuttonsâ: [
ânameâ: âmybutton1â,
âaddressâ: âAB:CD:EF:GH:IJ:00â,
âurlâ: âhttps://.duckdns.org:8123/api/services/light/toggleâ,
âheadersâ: â{âx-ha-accessâ: âmy_ha_api_paswdâ,âContent-Typeâ: âapplication/jsonâ}â,
âbodyâ: â{âentity_idâ: âlight.bathroomâ}â
As an almost irrelevant aside I have long wondered why this add-on is called dasshio (two sâs) and today I stumbled upon a similar add-on by @Pantomax which is also called dasshio. This made me think that maybe I was missing something obvious about the name?
Itâs a pun on haSSio. Iâd guess Pantomax is just duping the repositories of the add-ons he uses or wants to âfiddle withâ as itâs definitely @danimtbâs work.
Yes of course.
So obvious!
Iâm looking forward to it working againâŚ
Sorry, I was on holiday (still on) and was not able to make the release.
I have just released 0.3.1 fixing the authentication issue. Please update and report back
Note this was not a breaking change on Dasshio but a change on the way Hassio authenticates to interact with the HA API. Other addons were affected by this issue too.
Thanks a lot for the workarounds proposed before the fix was done and for the feedback!
Brilliant. It works!
Enjoy your holiday and thank you.
Hi @danimtb I have opened a new issue on github, it seems last homeassistant updates (v0.75.0) have broken the auth system again
Nope, all good, this one must be on you.
