hi
Xiaomi’s temperature detection is installed, as well as real-time power detection. But they can only work normally for a few hours, after which the data stops updating. Excuse me, what is this question
thank
2021-10-25 08:21:12 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration hive which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-10-25 08:21:12 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-10-25 08:21:12 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration xiaomi_miot which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-10-25 08:21:12 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration multizone_controller which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-10-25 08:21:25 WARNING (SyncWorker_3) [fake_useragent] Error occurred during loading data. Trying to use cache server https://fake-useragent.herokuapp.com/browsers/0.1.11
