i am new to homeassistant and have a question regarding my weather station. I collect my sensor data with rfxcom to meteohub. From meteohub i cn get over http the following data. Which is the best way to get this data into homeasistant. The sensors from the weather station should become a entity.
Many thanks for help.
<meteohub>
<config>
<language>de</language>
<temp_sensor unit="c" print="°C">th0</temp_sensor>
<hum_sensor unit="rel" print="%">th0</hum_sensor>
<dew_sensor unit="c" print="°C">th0</dew_sensor>
<baro_sensor unit="hpa" print="hPa">thb0</baro_sensor>
<wind_sensor unit="ms" print="m/s">wind0</wind_sensor>
<rain_sensor unit="mm" print="mm">rain0</rain_sensor>
<row number="1">last60m</row>
<row number="2">hour1</row>
<row number="3">day1</row>
<row number="4">month1</row>
</config>
<data timeframe="actual">
<item sensor="system" cat="version" unit="text">5.1d</item>
<item sensor="system" cat="version" unit="num">51</item>
<item sensor="system" cat="build" unit="num">7486</item>
<item sensor="system" cat="platform" unit="text">ALIX.1D_(500_MHz)</item>
<item sensor="system" cat="language" unit="text">German</item>
<item sensor="system" cat="temp" unit="unit">c</item>
<item sensor="system" cat="hum" unit="unit">rel</item>
<item sensor="system" cat="press" unit="unit">hpa</item>
<item sensor="system" cat="wind" unit="unit">ms</item>
<item sensor="system" cat="rain" unit="unit">mm</item>
<item sensor="date0" cat="date" unit="utc">20220221115417</item>
<item sensor="date0" cat="date2" unit="utc">21.02.2022 11:54:17</item>
<item sensor="date0" cat="puredate" unit="utc">21.02.2022</item>
<item sensor="date0" cat="time" unit="utc">11:54:17</item>
<item sensor="date0" cat="year" unit="utc">2022</item>
<item sensor="date0" cat="month" unit="utc">02</item>
<item sensor="date0" cat="day" unit="utc">21</item>
<item sensor="date0" cat="dayofweek" unit="utc">1</item>
<item sensor="date0" cat="hour" unit="utc">11</item>
<item sensor="date0" cat="min" unit="utc">54</item>
<item sensor="date0" cat="sec" unit="utc">17</item>
<item sensor="date0" cat="date" unit="local">20220221125417</item>
<item sensor="date0" cat="date2" unit="local">21.02.2022 12:54:17</item>
<item sensor="date0" cat="puredate" unit="local">21.02.2022</item>
<item sensor="date0" cat="time" unit="local">12:54:17</item>
<item sensor="date0" cat="year" unit="local">2022</item>
<item sensor="date0" cat="month" unit="local">02</item>
<item sensor="date0" cat="day" unit="local">21</item>
<item sensor="date0" cat="dayofweek" unit="local">1</item>
<item sensor="date0" cat="hour" unit="local">12</item>
<item sensor="date0" cat="min" unit="local">54</item>
<item sensor="date0" cat="sec" unit="local">17</item>
<item sensor="lunar" cat="phase" unit="percentage">76.0</item>
<item sensor="lunar" cat="age" unit="days">19</item>
<item sensor="lunar" cat="phase" unit="segment">5</item>
<item sensor="lunar" cat="phase" unit="de">Dreiviertelmond_(abnehmend)</item>
<item sensor="lunar" cat="phase" unit="en">Waning_Gibbous</item>
<item sensor="lunar" cat="phase" unit="es">Gibosa_Menguante</item>
<item sensor="lunar" cat="phase" unit="nl">Afnemende_maan</item>
<item sensor="lunar" cat="phase" unit="dk">Mere_end_halv,_aftagende</item>
<item sensor="lunar" cat="phase" unit="cz">Couvaj&iacute;c&iacute;_M&#283;s&iacute;c</item>
<item sensor="lunar" cat="phase" unit="hr">Vi&#353;e_od_polovice,_u_opadanju</item>
<item sensor="station" cat="longitude" unit="decimal">9.633889</item>
<item sensor="station" cat="latitude" unit="decimal">48.643889</item>
<item sensor="daylength" cat="standard" unit="hours">10.56</item>
<item sensor="daylength" cat="standard" unit="minutes">634</item>
<item sensor="daylength" cat="standard" unit="hhmm">10:34</item>
<item sensor="daylength" cat="civiltwilight" unit="hours">11.63</item>
<item sensor="daylength" cat="civiltwilight" unit="minutes">698</item>
<item sensor="daylength" cat="civiltwilight" unit="hhmm">11:38</item>
<item sensor="daylength" cat="nauticaltwilight" unit="hours">12.84</item>
<item sensor="daylength" cat="nauticaltwilight" unit="minutes">771</item>
<item sensor="daylength" cat="nauticaltwilight" unit="hhmm">12:51</item>
<item sensor="sunrise" cat="standard" unit="utc">06:18</item>
<item sensor="sunset" cat="standard" unit="utc">16:52</item>
<item sensor="sunrise" cat="standard" unit="local">07:18</item>
<item sensor="sunset" cat="standard" unit="local">17:52</item>
<item sensor="sunrise" cat="civiltwilight" unit="utc">05:46</item>
<item sensor="sunset" cat="civiltwilight" unit="utc">17:24</item>
<item sensor="sunrise" cat="civiltwilight" unit="local">06:46</item>
<item sensor="sunset" cat="civiltwilight" unit="local">18:24</item>
<item sensor="daynight" cat="flag" unit="local">D</item>
<item sensor="sunrise" cat="nauticaltwilight" unit="utc">05:10</item>
<item sensor="sunset" cat="nauticaltwilight" unit="utc">18:00</item>
<item sensor="sunrise" cat="nauticaltwilight" unit="local">06:10</item>
<item sensor="sunset" cat="nauticaltwilight" unit="local">19:00</item>
<item sensor="moonrise" cat="standard" unit="local">23:36</item>
<item sensor="moonrise" cat="standard" unit="utc">22:36</item>
<item sensor="moonset" cat="standard" unit="local">09:26</item>
<item sensor="moonset" cat="standard" unit="utc">08:26</item>
<item sensor="uv0" cat="index" unit="">3.0</item>
<item sensor="uv0" cat="lowbat" unit="">1</item>
<item sensor="th2" cat="temp" unit="c">20.4</item>
<item sensor="th2" cat="temp" unit="f">68.7</item>
<item sensor="th2" cat="hum" unit="rel">44</item>
<item sensor="th2" cat="hum" unit="abs">7.8</item>
<item sensor="th2" cat="dew" unit="c">7.7</item>
<item sensor="th2" cat="dew" unit="f">45.9</item>
<item sensor="th2" cat="heatindex" unit="c">20.4</item>
<item sensor="th2" cat="heatindex" unit="f">68.7</item>
<item sensor="th2" cat="humidex" unit="c">20.7</item>
<item sensor="th2" cat="humidex" unit="f">69.3</item>
<item sensor="th2" cat="cloudheight" unit="m">1588</item>
<item sensor="th2" cat="cloudheight" unit="ft">5080</item>
<item sensor="rain0" cat="rate" unit="mm">0.0</item>
<item sensor="rain0" cat="rate" unit="in">0.00</item>
<item sensor="rain0" cat="total" unit="mm">1063.7</item>
<item sensor="rain0" cat="total" unit="in">41.88</item>
<item sensor="rain0" cat="lowbat" unit="">1</item>
<item sensor="th0" cat="temp" unit="c">7.3</item>
<item sensor="th0" cat="temp" unit="f">45.1</item>
<item sensor="th0" cat="hum" unit="rel">52</item>
<item sensor="th0" cat="hum" unit="abs">4.1</item>
<item sensor="th0" cat="dew" unit="c">-1.9</item>
<item sensor="th0" cat="dew" unit="f">28.6</item>
<item sensor="th0" cat="heatindex" unit="c">7.3</item>
<item sensor="th0" cat="heatindex" unit="f">45.1</item>
<item sensor="th0" cat="humidex" unit="c">4.7</item>
<item sensor="th0" cat="humidex" unit="f">40.5</item>
<item sensor="th0" cat="cloudheight" unit="m">1150</item>
<item sensor="th0" cat="cloudheight" unit="ft">3680</item>
<item sensor="th0" cat="lowbat" unit="">1</item>
<item sensor="wind0" cat="dir" unit="deg">202</item>
<item sensor="wind0" cat="dir" unit="de">SSW</item>
<item sensor="wind0" cat="dir" unit="nl">ZZW</item>
<item sensor="wind0" cat="dir" unit="en">SSW</item>
<item sensor="wind0" cat="gustspeed" unit="ms">6.9</item>
<item sensor="wind0" cat="gustspeed" unit="kmh">24.8</item>
<item sensor="wind0" cat="gustspeed" unit="mph">15.4</item>
<item sensor="wind0" cat="gustspeed" unit="kn">13.4</item>
<item sensor="wind0" cat="gustspeed" unit="bft">4.1</item>
<item sensor="wind0" cat="gustspeed" unit="bftint">4</item>
<item sensor="wind0" cat="speed" unit="ms">5.9</item>
<item sensor="wind0" cat="speed" unit="kmh">21.2</item>
<item sensor="wind0" cat="speed" unit="mph">13.2</item>
<item sensor="wind0" cat="speed" unit="kn">11.5</item>
<item sensor="wind0" cat="speed" unit="bft">3.7</item>
<item sensor="wind0" cat="speed" unit="bftint">4</item>
<item sensor="wind0" cat="chill" unit="c">3.5</item>
<item sensor="wind0" cat="chill" unit="f">38.3</item>
</data>
<data timeframe="alltime">
<item sensor="date0" cat="date" unit="utc">20220221035035</item>
<item sensor="date0" cat="date" unit="local">20220221045035</item>
<item sensor="wind0" cat="maxspeeddir" unit="deg">180.0</item>
<item sensor="wind0" cat="maxspeeddir" unit="de">S</item>
<item sensor="wind0" cat="maxspeeddir" unit="nl">Z</item>
<item sensor="wind0" cat="maxspeeddir" unit="en">S</item>
<item sensor="wind0" cat="maindir" unit="deg">292.5</item>
<item sensor="wind0" cat="maindir" unit="de">WNW</item>
<item sensor="wind0" cat="maindir" unit="nl">WNW</item>
<item sensor="wind0" cat="maindir" unit="en">WNW</item>
<item sensor="wind0" cat="gustspeed" unit="ms">0.6</item>
<item sensor="wind0" cat="gustspeed" unit="kmh">2.2</item>
<item sensor="wind0" cat="gustspeed" unit="mph">1.4</item>
<item sensor="wind0" cat="gustspeed" unit="kn">1.2</item>
<item sensor="wind0" cat="gustspeed" unit="bft">0.8</item>
<item sensor="wind0" cat="gustspeed" unit="bftint">1</item>
<item sensor="wind0" cat="gustspeedmin" unit="time">20200308155610</item>
<item sensor="wind0" cat="gustspeedmin" unit="ms">0.0</item>
<item sensor="wind0" cat="gustspeedmin" unit="kmh">0.0</item>
<item sensor="wind0" cat="gustspeedmin" unit="mph">0.0</item>
<item sensor="wind0" cat="gustspeedmin" unit="kn">0.0</item>
<item sensor="wind0" cat="gustspeedmin" unit="bft">0.0</item>
<item sensor="wind0" cat="gustspeedmin" unit="bftint">0</item>
<item sensor="wind0" cat="gustspeedmax" unit="time">20210128142256</item>
<item sensor="wind0" cat="gustspeedmax" unit="deg">180</item>
<item sensor="wind0" cat="gustspeedmax" unit="ms">16.9</item>
<item sensor="wind0" cat="gustspeedmax" unit="kmh">60.8</item>
<item sensor="wind0" cat="gustspeedmax" unit="mph">37.8</item>
<item sensor="wind0" cat="gustspeedmax" unit="kn">32.9</item>
<item sensor="wind0" cat="gustspeedmax" unit="bft">7.4</item>
<item sensor="wind0" cat="gustspeedmax" unit="bftint">7</item>
<item sensor="wind0" cat="speed" unit="ms">0.6</item>
<item sensor="wind0" cat="speed" unit="kmh">2.1</item>
<item sensor="wind0" cat="speed" unit="mph">1.3</item>
<item sensor="wind0" cat="speed" unit="kn">1.1</item>
<item sensor="wind0" cat="speed" unit="bft">0.8</item>
<item sensor="wind0" cat="speed" unit="bftint">1</item>
<item sensor="wind0" cat="speedmin" unit="time">20200308193118</item>
<item sensor="wind0" cat="speedmin" unit="ms">0.0</item>
<item sensor="wind0" cat="speedmin" unit="kmh">0.0</item>
<item sensor="wind0" cat="speedmin" unit="mph">0.0</item>
<item sensor="wind0" cat="speedmin" unit="kn">0.0</item>
<item sensor="wind0" cat="speedmin" unit="bft">0.0</item>
<item sensor="wind0" cat="speedmin" unit="bftint">0</item>
<item sensor="wind0" cat="speedmax" unit="time">20210203205152</item>
<item sensor="wind0" cat="speedmax" unit="deg">202</item>
<item sensor="wind0" cat="speedmax" unit="ms">8.9</item>
<item sensor="wind0" cat="speedmax" unit="kmh">32.0</item>
<item sensor="wind0" cat="speedmax" unit="mph">19.9</item>
<item sensor="wind0" cat="speedmax" unit="kn">17.3</item>
<item sensor="wind0" cat="speedmax" unit="bft">4.8</item>
<item sensor="wind0" cat="speedmax" unit="bftint">5</item>
<item sensor="wind0" cat="chill" unit="c">12.7</item>
<item sensor="wind0" cat="chillmin" unit="time">20210213100902</item>
<item sensor="wind0" cat="chillmax" unit="time">20210403200539</item>
<item sensor="wind0" cat="chillmin" unit="c">-10.9</item>
<item sensor="wind0" cat="chillmax" unit="c">63.8</item>
<item sensor="wind0" cat="chilldelta" unit="c">-2.1</item>
<item sensor="wind0" cat="chill" unit="f">54.8</item>
<item sensor="wind0" cat="chillmin" unit="f">12.4</item>
<item sensor="wind0" cat="chillmax" unit="f">146.8</item>
<item sensor="wind0" cat="chilldelta" unit="f">28.2</item>
<item sensor="rain0" cat="rate" unit="mm">19.4</item>
<item sensor="rain0" cat="rate" unit="in">0.76</item>
<item sensor="rain0" cat="ratemin" unit="time">20200308155301</item>
<item sensor="rain0" cat="ratemin" unit="mm">0.0</item>
<item sensor="rain0" cat="ratemin" unit="in">0.00</item>
<item sensor="rain0" cat="ratemax" unit="time">20200511163931</item>
<item sensor="rain0" cat="ratemax" unit="mm">5000.0</item>
<item sensor="rain0" cat="ratemax" unit="in">196.85</item>
<item sensor="rain0" cat="total" unit="mm">1304.10</item>
<item sensor="rain0" cat="total" unit="in">51.34</item>
<item sensor="rain0" cat="total" unit="time">20220221034639</item>
<item sensor="rain0" cat="days" unit="">154</item>
<item sensor="thb0" cat="temp" unit="c">19.7</item>
<item sensor="thb0" cat="temp" unit="f">67.4</item>
<item sensor="thb0" cat="tempmin" unit="time">20200629035908</item>
<item sensor="thb0" cat="tempmax" unit="time">20200813105147</item>
<item sensor="thb0" cat="tempmin" unit="c">10.5</item>
<item sensor="thb0" cat="tempmin" unit="f">50.9</item>
<item sensor="thb0" cat="tempmax" unit="c">26.8</item>
<item sensor="thb0" cat="tempmax" unit="f">80.2</item>
<item sensor="thb0" cat="temp" unit="trend">1</item>
<item sensor="thb0" cat="tempdelta" unit="c">6.4</item>
<item sensor="thb0" cat="tempdelta" unit="f">11.5</item>
<item sensor="thb0" cat="dew" unit="c">6.7</item>
<item sensor="thb0" cat="dew" unit="f">44.0</item>
<item sensor="thb0" cat="dewmin" unit="time">20210112033437</item>
<item sensor="thb0" cat="dewmax" unit="time">20200813150157</item>
<item sensor="thb0" cat="dewmin" unit="c">-0.7</item>
<item sensor="thb0" cat="dewmin" unit="f">30.7</item>
<item sensor="thb0" cat="dewmax" unit="c">17.1</item>
<item sensor="thb0" cat="dewmax" unit="f">62.8</item>
<item sensor="thb0" cat="dew" unit="trend">1</item>
<item sensor="thb0" cat="dewdelta" unit="c">6.8</item>
<item sensor="thb0" cat="dewdelta" unit="f">12.2</item>
<item sensor="thb0" cat="heatindex" unit="c">19.7</item>
<item sensor="thb0" cat="heatindex" unit="f">67.4</item>
<item sensor="thb0" cat="heatindexmin" unit="time">20200629035908</item>
<item sensor="thb0" cat="heatindexmax" unit="time">20200813140303</item>
<item sensor="thb0" cat="heatindexmin" unit="c">10.5</item>
<item sensor="thb0" cat="heatindexmin" unit="f">50.9</item>
<item sensor="thb0" cat="heatindexmax" unit="c">27.5</item>
<item sensor="thb0" cat="heatindexmax" unit="f">81.5</item>
<item sensor="thb0" cat="heatindex" unit="trend">1</item>
<item sensor="thb0" cat="heatindexdelta" unit="c">6.4</item>
<item sensor="thb0" cat="heatindexdelta" unit="f">11.5</item>
<item sensor="thb0" cat="humidex" unit="c">19.7</item>
<item sensor="thb0" cat="humidex" unit="f">67.5</item>
<item sensor="thb0" cat="humidexmin" unit="time">20210616185828</item>
<item sensor="thb0" cat="humidexmax" unit="time">20200813140303</item>
<item sensor="thb0" cat="humidexmin" unit="c">8.5</item>
<item sensor="thb0" cat="humidexmin" unit="f">47.3</item>
<item sensor="thb0" cat="humidexmax" unit="c">32.1</item>
<item sensor="thb0" cat="humidexmax" unit="f">89.8</item>
<item sensor="thb0" cat="humidex" unit="trend">1</item>
<item sensor="thb0" cat="humidexdelta" unit="c">9.4</item>
<item sensor="thb0" cat="humidexdelta" unit="f">16.9</item>
<item sensor="thb0" cat="hum" unit="rel">43.2</item>
<item sensor="thb0" cat="hummin" unit="time">20210112001351</item>
<item sensor="thb0" cat="hummax" unit="time">20200617122755</item>
<item sensor="thb0" cat="hummin" unit="rel">31.0</item>
<item sensor="thb0" cat="hummax" unit="rel">63.0</item>
<item sensor="thb0" cat="hum" unit="trend">1</item>
<item sensor="thb0" cat="humdelta" unit="rel">0</item>
<item sensor="thb0" cat="press" unit="hpa">960.0</item>
<item sensor="thb0" cat="press" unit="psi">13.92</item>
<item sensor="thb0" cat="press" unit="mmhg">720.0</item>
<item sensor="thb0" cat="press" unit="inhg">28.35</item>
<item sensor="thb0" cat="pressmin" unit="time">20200629053524</item>
<item sensor="thb0" cat="pressmax" unit="time">20200627182005</item>
<item sensor="thb0" cat="pressmin" unit="hpa">856.0</item>
<item sensor="thb0" cat="pressmin" unit="psi">12.41</item>
<item sensor="thb0" cat="pressmin" unit="mmhg">642.0</item>
<item sensor="thb0" cat="pressmin" unit="inhg">25.28</item>
<item sensor="thb0" cat="pressmax" unit="hpa">1050.0</item>
<item sensor="thb0" cat="pressmax" unit="psi">15.23</item>
<item sensor="thb0" cat="pressmax" unit="mmhg">787.5</item>
<item sensor="thb0" cat="pressmax" unit="inhg">31.01</item>
<item sensor="thb0" cat="press" unit="trend">1</item>
<item sensor="thb0" cat="pressdelta" unit="hpa">3.0</item>
<item sensor="thb0" cat="pressdelta" unit="psi">0.04</item>
<item sensor="thb0" cat="pressdelta" unit="mmhg">2.2</item>
<item sensor="thb0" cat="pressdelta" unit="inhg">0.09</item>
<item sensor="thb0" cat="sealevel" unit="hpa">1008.2</item>
<item sensor="thb0" cat="sealevel" unit="psi">14.62</item>
<item sensor="thb0" cat="sealevel" unit="mmhg">756.2</item>
<item sensor="thb0" cat="sealevel" unit="inhg">29.77</item>
<item sensor="thb0" cat="sealevelmin" unit="time">20200629053524</item>
<item sensor="thb0" cat="sealevelmax" unit="time">20200627182005</item>
<item sensor="thb0" cat="sealevelmin" unit="hpa">904.2</item>
<item sensor="thb0" cat="sealevelmin" unit="psi">13.11</item>
<item sensor="thb0" cat="sealevelmin" unit="mmhg">678.2</item>
<item sensor="thb0" cat="sealevelmin" unit="inhg">26.70</item>
<item sensor="thb0" cat="sealevelmax" unit="hpa">1098.2</item>
<item sensor="thb0" cat="sealevelmax" unit="psi">15.93</item>
<item sensor="thb0" cat="sealevelmax" unit="mmhg">823.7</item>
<item sensor="thb0" cat="sealevelmax" unit="inhg">32.43</item>
<item sensor="thb0" cat="seapressdelta" unit="hpa">3.0</item>
<item sensor="thb0" cat="seapressdelta" unit="psi">0.04</item>
<item sensor="thb0" cat="seapressdelta" unit="mmhg">2.2</item>
<item sensor="thb0" cat="seapressdelta" unit="inhg">0.09</item>
<item sensor="th0" cat="temp" unit="c">13.1</item>
<item sensor="th0" cat="temp" unit="f">55.6</item>
<item sensor="th0" cat="tempmin" unit="time">20210213072025</item>
<item sensor="th0" cat="tempmax" unit="time">20210403200533</item>
<item sensor="th0" cat="tempmin" unit="c">-5.2</item>
<item sensor="th0" cat="tempmin" unit="f">22.6</item>
<item sensor="th0" cat="tempmax" unit="c">81.6</item>
<item sensor="th0" cat="tempmax" unit="f">178.9</item>
<item sensor="th0" cat="temp" unit="trend">-1</item>
<item sensor="th0" cat="tempdelta" unit="c">0.6</item>
<item sensor="th0" cat="tempdelta" unit="f">1.1</item>
<item sensor="th0" cat="dew" unit="c">4.9</item>
<item sensor="th0" cat="dew" unit="f">40.8</item>
<item sensor="th0" cat="dewmin" unit="time">20210213072025</item>
<item sensor="th0" cat="dewmax" unit="time">20210403200533</item>
<item sensor="th0" cat="dewmin" unit="c">-13.8</item>
<item sensor="th0" cat="dewmin" unit="f">7.2</item>
<item sensor="th0" cat="dewmax" unit="c">81.6</item>
<item sensor="th0" cat="dewmax" unit="f">178.9</item>
<item sensor="th0" cat="dew" unit="trend">-1</item>
<item sensor="th0" cat="dewdelta" unit="c">0.5</item>
<item sensor="th0" cat="dewdelta" unit="f">0.9</item>
<item sensor="th0" cat="heatindex" unit="c">13.1</item>
<item sensor="th0" cat="heatindex" unit="f">55.6</item>
<item sensor="th0" cat="heatindexmin" unit="time">20210213072025</item>
<item sensor="th0" cat="heatindexmax" unit="time">20210403200533</item>
<item sensor="th0" cat="heatindexmin" unit="c">-5.2</item>
<item sensor="th0" cat="heatindexmin" unit="f">22.6</item>
<item sensor="th0" cat="heatindexmax" unit="c">1009.0</item>
<item sensor="th0" cat="heatindexmax" unit="f">1848.2</item>
<item sensor="th0" cat="heatindex" unit="trend">-1</item>
<item sensor="th0" cat="heatindexdelta" unit="c">0.6</item>
<item sensor="th0" cat="heatindexdelta" unit="f">1.1</item>
<item sensor="th0" cat="humidex" unit="c">12.8</item>
<item sensor="th0" cat="humidex" unit="f">55.0</item>
<item sensor="th0" cat="humidexmin" unit="time">20210213072025</item>
<item sensor="th0" cat="humidexmax" unit="time">20210403200533</item>
<item sensor="th0" cat="humidexmin" unit="c">-9.6</item>
<item sensor="th0" cat="humidexmin" unit="f">14.7</item>
<item sensor="th0" cat="humidexmax" unit="c">401.1</item>
<item sensor="th0" cat="humidexmax" unit="f">754.0</item>
<item sensor="th0" cat="humidex" unit="trend">-1</item>
<item sensor="th0" cat="humidexdelta" unit="c">0.8</item>
<item sensor="th0" cat="humidexdelta" unit="f">1.4</item>
<item sensor="th0" cat="hum" unit="rel">58.9</item>
<item sensor="th0" cat="hummin" unit="time">20210427164907</item>
<item sensor="th0" cat="hummax" unit="time">20210403200533</item>
<item sensor="th0" cat="hummin" unit="rel">21.0</item>
<item sensor="th0" cat="hummax" unit="rel">128.0</item>
<item sensor="th0" cat="hum" unit="trend">-1</item>
<item sensor="th0" cat="humdelta" unit="rel">0</item>
<item sensor="th1" cat="temp" unit="c">10.5</item>
<item sensor="th1" cat="temp" unit="f">50.9</item>
<item sensor="th1" cat="tempmin" unit="time">20210212031714</item>
<item sensor="th1" cat="tempmax" unit="time">20200731163950</item>
<item sensor="th1" cat="tempmin" unit="c">-9.7</item>
<item sensor="th1" cat="tempmin" unit="f">14.5</item>
<item sensor="th1" cat="tempmax" unit="c">31.0</item>
<item sensor="th1" cat="tempmax" unit="f">87.8</item>
<item sensor="th1" cat="temp" unit="trend">1</item>
<item sensor="th1" cat="tempdelta" unit="c">10.2</item>
<item sensor="th1" cat="tempdelta" unit="f">18.4</item>
<item sensor="th1" cat="dew" unit="c">-2.7</item>
<item sensor="th1" cat="dew" unit="f">27.2</item>
<item sensor="th1" cat="dewmin" unit="time">20210215035028</item>
<item sensor="th1" cat="dewmax" unit="time">20200822120424</item>
<item sensor="th1" cat="dewmin" unit="c">-23.0</item>
<item sensor="th1" cat="dewmin" unit="f">-9.4</item>
<item sensor="th1" cat="dewmax" unit="c">16.8</item>
<item sensor="th1" cat="dewmax" unit="f">62.2</item>
<item sensor="th1" cat="dew" unit="trend">1</item>
<item sensor="th1" cat="dewdelta" unit="c">13.9</item>
<item sensor="th1" cat="dewdelta" unit="f">25.0</item>
<item sensor="th1" cat="heatindex" unit="c">10.5</item>
<item sensor="th1" cat="heatindex" unit="f">50.9</item>
<item sensor="th1" cat="heatindexmin" unit="time">20210212031714</item>
<item sensor="th1" cat="heatindexmax" unit="time">20200731163950</item>
<item sensor="th1" cat="heatindexmin" unit="c">-9.7</item>
<item sensor="th1" cat="heatindexmin" unit="f">14.5</item>
<item sensor="th1" cat="heatindexmax" unit="c">31.0</item>
<item sensor="th1" cat="heatindexmax" unit="f">87.8</item>
<item sensor="th1" cat="heatindex" unit="trend">1</item>
<item sensor="th1" cat="heatindexdelta" unit="c">10.2</item>
<item sensor="th1" cat="heatindexdelta" unit="f">18.4</item>
<item sensor="th1" cat="humidex" unit="c">8.1</item>
<item sensor="th1" cat="humidex" unit="f">46.5</item>
<item sensor="th1" cat="humidexmin" unit="time">20210212031714</item>
<item sensor="th1" cat="humidexmax" unit="time">20200821150539</item>
<item sensor="th1" cat="humidexmin" unit="c">-14.5</item>
<item sensor="th1" cat="humidexmin" unit="f">5.9</item>
<item sensor="th1" cat="humidexmax" unit="c">28.9</item>
<item sensor="th1" cat="humidexmax" unit="f">84.0</item>
<item sensor="th1" cat="humidex" unit="trend">1</item>
<item sensor="th1" cat="humidexdelta" unit="c">13.4</item>
<item sensor="th1" cat="humidexdelta" unit="f">24.1</item>
<item sensor="th1" cat="hum" unit="rel">43.9</item>
<item sensor="th1" cat="hummin" unit="time">20200730163109</item>
<item sensor="th1" cat="hummax" unit="time">20210624040913</item>
<item sensor="th1" cat="hummin" unit="rel">11.0</item>
<item sensor="th1" cat="hummax" unit="rel">93.0</item>
<item sensor="th1" cat="hum" unit="trend">-1</item>
<item sensor="th1" cat="humdelta" unit="rel">0</item>
<item sensor="uv0" cat="index" unit="">0.7</item>
<item sensor="uv0" cat="indexmax" unit="time">20210514113553</item>
<item sensor="uv0" cat="indexmax" unit="">15.0</item>
<item sensor="th2" cat="temp" unit="c">23.5</item>
<item sensor="th2" cat="temp" unit="f">74.3</item>
<item sensor="th2" cat="tempmin" unit="time">20220221034421</item>
<item sensor="th2" cat="tempmax" unit="time">20200811130325</item>
<item sensor="th2" cat="tempmin" unit="c">20.1</item>
<item sensor="th2" cat="tempmin" unit="f">68.2</item>
<item sensor="th2" cat="tempmax" unit="c">32.5</item>
<item sensor="th2" cat="tempmax" unit="f">90.5</item>
<item sensor="th2" cat="temp" unit="trend">-1</item>
<item sensor="th2" cat="tempdelta" unit="c">-12.3</item>
<item sensor="th2" cat="tempdelta" unit="f">-22.1</item>
<item sensor="th2" cat="dew" unit="c">9.6</item>
<item sensor="th2" cat="dew" unit="f">49.2</item>
<item sensor="th2" cat="dewmin" unit="time">20210424134214</item>
<item sensor="th2" cat="dewmax" unit="time">20200811130325</item>
<item sensor="th2" cat="dewmin" unit="c">1.7</item>
<item sensor="th2" cat="dewmin" unit="f">35.1</item>
<item sensor="th2" cat="dewmax" unit="c">20.4</item>
<item sensor="th2" cat="dewmax" unit="f">68.7</item>
<item sensor="th2" cat="dew" unit="trend">-1</item>
<item sensor="th2" cat="dewdelta" unit="c">-12.8</item>
<item sensor="th2" cat="dewdelta" unit="f">-23.0</item>
<item sensor="th2" cat="heatindex" unit="c">23.5</item>
<item sensor="th2" cat="heatindex" unit="f">74.4</item>
<item sensor="th2" cat="heatindexmin" unit="time">20220221034421</item>
<item sensor="th2" cat="heatindexmax" unit="time">20200811130325</item>
<item sensor="th2" cat="heatindexmin" unit="c">20.1</item>
<item sensor="th2" cat="heatindexmin" unit="f">68.2</item>
<item sensor="th2" cat="heatindexmax" unit="c">35.0</item>
<item sensor="th2" cat="heatindexmax" unit="f">95.0</item>
<item sensor="th2" cat="heatindex" unit="trend">-1</item>
<item sensor="th2" cat="heatindexdelta" unit="c">-14.8</item>
<item sensor="th2" cat="heatindexdelta" unit="f">-26.6</item>
<item sensor="th2" cat="humidex" unit="c">24.7</item>
<item sensor="th2" cat="humidex" unit="f">76.5</item>
<item sensor="th2" cat="humidexmin" unit="time">20210425132940</item>
<item sensor="th2" cat="humidexmax" unit="time">20200811130325</item>
<item sensor="th2" cat="humidexmin" unit="c">18.9</item>
<item sensor="th2" cat="humidexmin" unit="f">66.0</item>
<item sensor="th2" cat="humidexmax" unit="c">40.4</item>
<item sensor="th2" cat="humidexmax" unit="f">104.7</item>
<item sensor="th2" cat="humidex" unit="trend">-1</item>
<item sensor="th2" cat="humidexdelta" unit="c">-19.9</item>
<item sensor="th2" cat="humidexdelta" unit="f">-35.8</item>
<item sensor="th2" cat="hum" unit="rel">41.8</item>
<item sensor="th2" cat="hummin" unit="time">20210329135447</item>
<item sensor="th2" cat="hummax" unit="time">20210607182524</item>
<item sensor="th2" cat="hummin" unit="rel">25.0</item>
<item sensor="th2" cat="hummax" unit="rel">65.0</item>
<item sensor="th2" cat="hum" unit="trend">1</item>
<item sensor="th2" cat="humdelta" unit="rel">0</item>
</data>
</meteohub>
