Hi, I’m trying to work out the best method to get data from an electricity meter. Picture below. It doesn’t seem to have any ports, and I’m not sure if there’s a regular flashing LED. So perhaps the clamp?
If you want something that works out of the box, I recommend Shelly EM (with clamp).
Otherwise try if the IR-led is activated for pulses. It should flash every Wh and you should see it with phone camera. In that case Esphome devboard and phototransistor can measure your consumption.
